Update: I got this error on device with Android 6.0. App works fine a device with Android 5.1
strange, I tried and got an error:
Processing changes to: Error: java.lang.SecurityException: Neither user 2000 nor current process has android.permission.MANAGE_USERS.
To satya: are you sure about the 1% battery level? With this low level, the watch should not run. Probably
this information from the battery status is wrong.
The information is not bad because clock is off. The factory launcher has no such problem.
What kind of watch do you have? I’m using a Q7 and the battery status on my watch is correct. Do you check the status on a watch face or when you swipe down on the launcher?
KW88. Latest firmware. I deleted the launcher. Now ok.
This is very strange. You could tray to check your battery status. I used this app:
play.google.com/store/apps/details?id=com.bat.lifebattery
I found some problems with cells on my watch. How is your battery live in general? Is it more the 24h after full charge?
Oct 7, 2017 14:30:30 GMT 1 satya said:
 Battery indicator still bad. Show me 92%....after then turn off the watch, and i plug in the charger, and show the display (battery 1%).
I have similar problem with my I4 Pro. When the watch is charged let’s say till 100%, while it is on, then switching it off and connecting to charger, always show 13-15% less. But this issue is not launcher dependent. I have the same effect with stock launcher
use the above app to check your battery. I’ve similar problems with my watch, still not great but much better. Also disable all the app’s you don’t need.
Thank You, but this did not help
search for a wakelock app (probably needs root)to see what drains your battery
Mate, the battery is not draining. I achieved 1.5%/hour when checking the watch and about 3% with reading smth via wifi.
The battery looses 13-15% of charge ONLY while it is switching OFF, which is very very strange
Sorry I get it now. This is very strange.
hi Ricktop, one question plz, some of watchmaker actions like for example gradient color for markers and numbers does not work on the watch, it showes me one color on the watch, on the other hand with the images i add to watchmaker it show me a gradient color on the watch but not with the right angle, i have a les1, i only wanted to know if this bug is from the watch, the launcher or the android sistem and is it possible to fix it?
thank you for your hard work this launcher is awesom.
Oct 10, 2017 11:01:12 GMT 1 cojackck said:
hi Ricktop, one question plz, some of watchmaker actions like for example gradient color for markers and numbers does not work on the watch, it showes me one color on the watch, on the other hand with the images i add to watchmaker it show me a gradient color on the watch but not with the right angle, i have a les1, i only wanted to know if this bug is from the watch, the launcher or the android sistem and is it possible to fix it? thank you for your hard work this launcher is awesom.
Surely it's the launcher. give the skin reference in order i can check if it's supported or not.
www.dropbox.com/s/dowhjiwbqiqat2y/gold-kojack-copy.watch?dl=0
this is an example watch
-marker and numbres does not change color on the watch
-the month number is a gradient color, on the watch it is static color
-the word WATCH MAKER and the 2 lines are gradient color and shows a gradient color but not in the right angle on the watch
the snow image is not moving on the watch. thankssss
2.3.3 published :
  • array 99 corrected
  • counters supported on .watch format.
Thanks for your work. There is a small error in the description you wrote 2.2.3
Oct 12, 2017 8:50:16 GMT 1 ricktop said:
2.3.3 published : - array 99 corrected - counters supported on .watch format.
Good work Ricktop!
What other features should I be on the lookout for other than array 99 being corrected and counters supported?
Any bug fixes?
Also, you’ve got the version wrongly named as 2.2.3 instead of 2.3.3 I guess!
Am I the only one who has trouble with the notifications? (Only the watchface appears when the watch (DM368) gets a notification.)
Notification works fine on my LEMFO LES1
Anyone has tested the widget? I’m trying with spotify, but so far I was unable to make it work. I can see buttons, but I cannot play music, even if it is store directly into the smartwatch. Any help?
