@kawaxa What am I supposed to do with such a comment ? What is your issue ?
Great work. Is there any link to download the watchface folder zip as shown in video? Thanks
Hello Eric Crochemore!
Are you working on activating Phone/Device/Tasker tags or its impossible to port on Full Android Watches?
Can I somehow make work buttons to open watch apps? Like maps or settingsā¦
Would it be possible for the Double Tap āchange watch faceā, To have another option for a 2 finger double tap?
I like the double tap for changing watch faces, but i often accidentally bring it up when trying to swipe quickly. Or when trying to prevent the screen from going to sleep. When it auto-dims.
I think most if not all of these watches support multi-touch.
Or double tap then hold. So hold for a couple seconds on the second tap.
Version 3.0 published :
- added support of temperature unit on clockskin format (arraytype 1011)
- support of 64bits library added
- clockskin bugs solved
- watchmaker bugs solved
Fantastic news eric . Thankyou as always
Wow, thats great! Now we can create faces that can switch between °C and °F! Letās go for it! Thank you, Eric!!!
thanks. thats great!
Thanks , @Eric_Crochemore we are thankful that you are constantly improving app.
Warm regards
Awesome, Iād be using wearOS if it wasnāt for your awesome launcher
@Eric_Crochemore
Got a bug, but iām not sure if itās a UL bug or just how watch-faces are handled.
In this watch face. When going from 11:00, to 12:00, to 01:00, they donāt function properly if i donāt set the watch to 24 hour mode in the Date & time settings.
For example, in the light rose face, at 12:00 only the top rose should be light. All the others should be deep red. At 1:00, the top and 1 oāclock rose should be light.
These use a 12 hour digital indicator layer.
However if the watch is set to 12 hour mode, at 12:00, all the roses are light.
Itās a of a problem for people who use strictly 12h time modes to have to switch to a 24h mode just for a single watch face.
Thereās a hidden feature that could solve the issue : you can force the hour format like this.
Add the āhourFormatā element in the related drawable using one of those values ā0-11ā ā1-12ā ā0-23ā ā1-24ā.
For example :
<drawable>
<name>digital1.xml</name>
<arraytype>7</arraytype>
<centerX>-200</centerX>
<centerY>0</centerY>
<hourFormat>0-23</hourFormat>
</drawable>
Thatās nice. I didnāt noticedā¦
Thatās why i called it āhiddenā ⦠![]()
Thatās a good point!
Took me a while to figure it out, but i got it!
Had to use 0-11 on digital1 and digital2. i forgot to use it on digital2 so it kept funking out on me. But yeah i got it now.
Thank you!
Thanks, it worked. The one thing that I cannot make it work is to display the Heart Rate. Iāll continue trying things.
If you have a watch face that shows the heart rate and you have activated the heart rate in menu in UL there is no reason why it shouldnt work at all .
I have an Microwear H1. The heart rate feature works fine in the build-in smartwatch software, but in UL skins it always shows 0 BPM. Of course I activated the heart rate in the menu in UL, and in settings.
Did you restart the launcher?
