How to convert .zip to .watch?
just rename .watch to .zip and when finished .zip to .watch
Nothing has changed, the face is invisible
Does Uniwersal Launcher support all .watch faces, those for Wear OS too?
@padington Give a link to the face, I will look.
Just tried it on my Optimus Pro with no luck. It appears in the watchface list and the preview image shows. However when I select it I just get a blank screen.
I have noticed that a few of the .watch format faces that I have installed display incorrectly. For example the free Watchmaker skin ā€œSweeperā€ is missing it’s radar style background and only displays the numbers.
Ok, issue found. This skin uses some formula on radius… which was not expected. It’s working fine now. Wait for next release of UL.
By the way, very interesting skin, it will probably be my favorite… :smile:
Super, I’m waiting impatiently :grinning:
I have noticed a small bug in a few of the .watch faces that I have used.
Faces that show text for the charging state show incorrect text. They display either ā€œTESTTESTTESTā€ or ā€œFALSEā€.
I also had an issue with a face from WatchMaker displaying wrong. The face ā€œTransformers Watch Color 12h/24hā€ shows nothing but the faction symbol at the bottom, the face appears to be totally black except for that bottom logo.
Not sure if I am allowed to upload it but if you search the name on watchmaker you should find it pretty easily (it’s a mostly grey digital face).
Thanks for this awesome launcher, it is very useful and quite impressive :slight_smile:
Something else I just realised I forgot to mention.
I found a really awesome Pipboy watchface ā€œPipboy 3001ā€, that is very interactive and generally works really well (great work on the watchface engine). But not all the features of the face work.
The watchface can show things like maps, phone battery, calendar entries and device temp. At the moment these don’t seem to work. Have I just missed some setup?
I noticed that weather works, so I was a bit surprised that maps won’t show.
Hello,
I have a Thor 4 Pro. After installing the Universal Launcher the watchface keeps staying in the bottom right of the screen, doesn’t matter if I click the power button and go to full screen mode.
Is there any solution for this?
Thanks.
This happened to me once . After a normal restart the problem was fixed when watch re-booted
No, those feature are not supported.
Yes, you need to restart the launcher after going to full round mode. For that you can restart the watch or just restart the launcher using the restart option…
It means the skin is not supported.
installed the universal launcher again, because of your reply, and it is working great now.
Thank you!
Are there any plans to support these features (maps, calendar, temp, etc)?
It seems like it should be possible to get most of the data that would come from the phone directly from the watch. For example, calendar data could be pulled from google calendar on the watch if it is installed.
However even if these features never come, it is awesome that we can use Wear faces on non-Wear devices at all.
Normally calendar is supported, fot the other features, it would require CPU, so I’m not planning it.
Universal launcher does not work well with zeblaze thor 4 pro
