The pedometer needs to be polled at a defined rate, to save battery, I have chosen to use a low rate refresh. So 8 steps is not bad at all.
Eric, first THANKS ! Awesome Job !!
I install your laucher at my Kospet Brave and it“s awesome !
I“m facing some details, maybe I“m doing someting wrong:
- Thereās no faces that is capable to show the step meter⦠Just show 000000 anytime.
- The laucher broke some original apps in 3 or 4 icons with other names (like Kct Sports, phone, bt call).
- The compass, step meter and step archive just goneā¦
- There“s no weather app that works fine over the laucher
What I“m doing wrong ?
Sandro
@Eric_Crochemore does function on_display_bright() work on ul? Also will transitions = { āHSV Fadeā } (or similar) and
var_transition = transitions[transitionNo] be supported? I have the tap function next_scene() working but the actual transition isnāt. I have tried all 46 of them. thanks for any reply
No transition is supported and the on_display_bright is not.
@Eric_Crochemore ok thanks for clearing that up.
Hi! ⦠Iāve installed Unversal Launcher New Generation on my H1 (Microwear), but for some reason itĀ“s not reading the heart rate from the build-in sensor, any ideas of what to do?
Thanks!
You mean itās not reading the previous value measured by the system app ? Thatās normal. But you can activate HRM with the icon when double touch setting screen, then it will measure and show in skins.
I donāt fully understand this:
That means that I have to go to settings and double touch ⦠where?
If I go to settings I have: āHeart Rate Monitorā and I can enable or disable it. Of course I have it enabled, but it still doesnāt show the heart rate (it shows 0 BPM). I also had enabled the option in the sking, but still the same result.
No, double tap on a skin opens a setting window where you can activate the HRM.
Yes, I did that but it still is not showing the heart rate, it only display zero all the time. And I also have another question: is there a way to force the weather information refresh? ⦠It shows the same value always, and I have the smartwatch connected with WIFI and everything ā¦
Thanks for taking the time for answering me, I really apreciate it!!!
My watch is Kospet Hope. I like the universal launcher v2.3 more than the latest version. Because the icons of apps are more clearly than the newest version, less buggy, and also without the stopwatch and calculated. The only problem is I cannot get the weather(location) working on version 2.3. Is there any way to fix the weather on v2.3 or fix the DPI on newest version. The DPI setting is working with the newest version, but not working as good as v2.3. Thanks very much for your work on this beautiful launcher.
No, there is no way to make the weather work in the old versions.
Did you notice that you can use Icon Packs in the newer versions? So you can make them look however you want.
I am a little bit confused that you are saying that the newer Version are ābuggyā. Iām using it on 6 different watches, without any problems.
@G1NT0N1C is right, new version works without any special dpi setting on the hopeā¦
Thank you so much for your reply. I will check the newest version again.
Sorry, I searched this thread and also scrolled through but couldnāt find anything related. There are so many posts that Iām not sure itās returning all results:
The launcher I got from the Play Store yesterday, which I assume is the latest version, seems to have a bug: I canāt turn on or off the cellular data from the cellular data icon in the list of icons above Bluetooth/Wifi/etc.
If cellular data has already been off from the MainActivity (default launcher), then when I use the universal launcher āalwaysā I can never change it from the list of icons.
(Also, tapping on the 4G bars icon on the other screen shows the SIM status but doesnāt allow me to turn on/off either.)
So I have to go to MainActivity to turn on cellular data. Then when Iām back on universal launcher in āalwaysā mode, again I canāt turn OFF cellular data in the set of icons. (And the 4G bars icon now shows active status but doesnāt allow changed either.)
Finally using Airplane mode doesnāt help either because it just turns the status to whatever used to be on the MainActivity (if cellular data was on there, then airplane mode on/off restores it that way).
tldr I would like to be able to set cellular data right from the universal launcher but canāt figure out any way without MainLauncher.
Thatās a known restriction of the latest watch FW, this is not a launcher issue⦠We still hope that the company will put back the cellular data menu in their FWā¦one dayā¦
Is there a way to force the weather information refresh? ⦠It shows the same value always, and I have the smartwatch connected with WIFI and everything ā¦
You have to set your location. Eric had make a video about it. Youāll find it on our YouTube channel.
Hello Eric,
Why are some faces with the .watch extension invisible in the Uniwersal Launcher?
It can come from the ZIP version used to make the .watch. In this case, usually unzipping the .watch and zipping again will create a āreadableā .watch face.
