Sept 8, 2017 18:12:42 GMT 1 ricktop said:
Sept 8, 2017 15:51:21 GMT 1 nameless said:
Forgot to ask earlier: google calendar support means we can see/use watchmakers calendar tags?  What’s that hour and minute functions?
Yes calendar tags now read Google calendar. On_Hour on_minute are new function for schedule
please make universal launcher compatible for amazfit watch.I can run most android apk with adb install.Last final thing is a perfect launcher as yours.But But I got 'no matching abi' error when try to install.I think there is something about arm.PLease fix this .Amazfit must include in this forum has lots of users
It has already been discussed, this watch uses an unsupported CPU, also the OS is not a full Android. We’re not talking of a “fix” here… Sadly.
Very interesting skin and working quite well with rictop launcher
drive.google.com/file/d/0B-Woj4xQPCRIMnY3VUFubmNSNnc/view
All credit go to Javs Mb
I have a problem, my kw88 with universal launcher does not display AM PM.
Is there any Salucion?
regards
This is bug?
The repeating events in calendar are not visible at all, only one time events are available.
Have tried on different skins
Is it possible to fix?
Sept 21, 2017 9:59:52 GMT 1 nameless said:mtibee
did you try to restart watch? Did you enabled notifications for Eric’s launcher?
yawa
and even that I didn’t have any probs earlier with notifications I can see that scrolling between them is a lot smoother. And I love white on black (aka high contrast)! Thx ricktop
! You’r the man!
As mtibee said, notifications are still not perfect. Yes, from time to time I still need to restart the watch. But, yes, ricktop , I love your launcher!
I installed the latest version 2.3.2 on my I4 Air and am having the same problem as on my Thor. When I double tap the watchface I get a vibration but the watchface function does not open to show the other faces. It takes a reboot to get it to work. It appears it does not happen with every watch face displayed. Only select ones. Not sure it is worth fretting over yet.
Hi,Erick
I love your louncher, it’s make my Finow x5 air look different
Small suggestion Instead tapping 2 times to change skin may be you can do 3 or 4 times
some of the .watch faces change skin or have some extra fitures when you tap 2 times and it’s a conflict with your faces changing gesture
Thank you
Excelente launcher podrías venderlo a los fabricantes… Una acotación de mi parte es que las notificaciones no sean tan invasivas, a veces me sucede que llegan y se cambia automáticamente a esa pantalla, mientras intento hacer otra cosa con el reloj… Solo eso por el momento… Saludos y sigue así…
It has already been discussed, this watch uses an unsupported CPU, also the OS is not a full Android. We're not talking of a "fix" here... Sadly.
Bug Report
Hi ricktop,
I found a bug, just noticing this in version 2.3.2 and equally same on 2.3.1 (having reverted to be sure it wasn’t just 2.3.2).
changing the watch face on the launcher without reboot (pedometer values (steps, heart beat), weather data) remains sticky (reflect on selected watch face.
changing the watch face on the launcher with reboot (pedometer values (steps, heart beat), weather data) is reset to zero (0) and began a fresh count (steps) without syncing from the ‘Health’ app and obtain fresh weather data (internet and location) otherwise remains zero.
Confirming with the default launcher (switching to default launcher) both weather and pedometer data remains sticky (syncing from both weather and Health app) across watch faces with/out reboot.
…This was noticed on D5 smartwatch, don’t know if it’s generic or specific.
 Thank you for your contributions!
Can be used on H1 Microwear?
Bug Report
Hi ricktop,
You’re right, this is an old bug. I’m trying to  solve it for next release.
Yes probably.
Can I install on H1 Microwear. It is possible on FunOS?
Sept 12, 2017 10:20:21 GMT 1 scytalemk said:
This is great! Shame I can't use it with all functionality on my Finow Q3 Plus and Microwear H1 with FunOs.
Hi, what functionality doesn’t work? Is it possible to install on FunOS?
yes you can install on FunOS,work fine on my qw09…
No github ?
Runs perfectly, thnx
Any sight on planning for battery charging tags?
Hello Eric!
    Your Launcher looks great, and it works in a DM98 android 4.4.2 smartwatch too. The only problem is the resolution (320x240), it have got a wider screen, and white area in the right side.
if the skin could be centered…and and the backgound could be the same ase the clock skin… it could be usuable with Lemfo LEM4, Domino DM98 etc.
I’ll try to do it for next release.
