Hi, great launcher, I like it a lot and it’s my favorite. The question is that I noticed that when you press the power button takes longer to turn on to see the time that the launcher stock. Can it be adjusted to be faster? My watch is a zeblaze thor 4 … Thanks
Hello, I am totally new to Smartwatches. I have just received my Zeblaze Thor 4. The stock watch faces are pretty bad and I would like to install new ones. I am using an iPhone X, I do not own an Android phone. I have WiiWatch 2 on IPhone installed. The watch and iPhone are connected. Thats about all I know for now. Can someone direct me as to what I need to install and the procedure for doing so. I am clueless as to how to go about installing watch faces. I really like the Bone Head watch faces but at this point anything but the stock Thor 4 faces. I have installed WatchMaker but do not understand the procedure for installing watch faces using this app. Thank you so much for your time.
google is your friend even this forum has Youtube video
Jul 25, 2018 18:35:07 GMT 1 h5 said:Jun 29, 2018 3:51:09 GMT 1 kensupen said:
Sorry about that. When I edited my post, it removed the link.
Hello kensupen,I tried your faces and they would be great if they would work. One problem is that it actually does’t change from AM to PM. Then at 8 PM, the clock resets to 0 hour.
But the first part, the AM works. Can you fix the rest?
Can you tell me what face you are using? Also, is your watch set to 12 or 24h?
Jul 25, 2018 19:16:10 GMT 1 ivanstanco said:
I have only few problems: 1. "Hand bright screen" button does not work, because if I turn it off, the screen still wakes up when I turn my wrist, what can I do?
Did you disable wrist gesture in Watch system settings too?
Jul 26, 2018 14:34:17 GMT 1 nameless said:Jul 25, 2018 19:16:10 GMT 1 ivanstanco said:
If I go in settings/power saving and deselect the wrist gestures, the gesture stops, but if I use the fast menu it remains off: the problem is that I can’t enable or disable the wrist gesture from fast menu (sliding down and tapping “hand bright screen” button) but only going in the settings menu. (Sorry for bad english)
Jul 26, 2018 16:26:13 GMT 1 ivanstanco said:Jul 26, 2018 14:34:17 GMT 1 nameless said:
If I go in settings/power saving and deselect the wrist gestures, the gesture stops, but if I use the fast menu it remains off: the problem is that I can't enable or disable the wrist gesture from fast menu (sliding down and tapping "hand bright screen" button) but only going in the settings menu. (Sorry for bad english)
Those are two different settings, so use mine or the system one, but not both.
You can’t use watchmaker to put skins, just put the skin file on the watch clockskin directory. Look the YT channel tutorial.
Jul 26, 2018 18:38:55 GMT 1 ricktop said:Jul 26, 2018 16:26:13 GMT 1 ivanstanco said:
Sorry, how can I use yours if it does not work? I tried to use the new launcher function but it does nothing. Is there a hyde menu I can use?
Jul 26, 2018 23:19:27 GMT 1 ivanstanco said:Jul 26, 2018 18:38:55 GMT 1 ricktop said:
So if mine doesn’t work (your watch may be not compatible) use the system one.
Hi.
I am loving this launcher. What I nice work!
I noticed though that the step count (for me) always starts at a number higher then 17900.
The counter works as the steps are incremented but when I start my day the counter is already showing 17900+ steps and not zero as it should. Watch counter starts at zero.
This happens with all watch faces I tested with the Universal Launcher.
My watch is a Tenfifteen F2.
Thanks!
Jul 27, 2018 13:04:47 GMT 1 cheikemate said:
Hi.I am loving this launcher. What I nice work!
My watch is a Tenfifteen F2.Thanks!
Probably your watch reacts not like others. That’s sad.
OK.
Jul 27, 2018 19:12:38 GMT 1 ricktop said:Jul 27, 2018 13:04:47 GMT 1 cheikemate said:
Probably your watch reacts not like others. That's sad.
Thank you Sir for your hard work on this Launcher. I am a newbie with Android Smartwatches. I just purchased and received a Thor 4. I installed the Universal Launcher New Gen. and trying to install new watch faces using your launcher and procedures as noted on the YouTube channel. I have an older Microsoft laptop and attempted to install watch faces. The laptop was able to recognize Thor 4 watch but it was not showing any of the files on Thor 4. The computer said the watch was disconnected and so on. I was not able to install the new watch faces. I also tried using my MacBook Pro without success. Do you have any further suggestions as to what I might do in order to add new watch faces? Any help for this newbie will be greatly appreciated. Thank you.
Jul 27, 2018 7:13:26 GMT 1 ricktop said:Jul 26, 2018 23:19:27 GMT 1 ivanstanco said:
So if mine doesn't work (your watch may be not compatible) use the system one.
Ok, thank you for reply.
2.6 published :
- NEW live heart rate monitoring update (toggle on the double tap dialog box)
- NEW integrated calculator and chronometer apps after app launcher with left swipe
- NEW support Marco set skin command
Check your USB cable Check your MTP driver is well installed Check that you have activated MTP in USB connection setting YT channel is your friend. If still not working, open another thread for help.
Jul 28, 2018 22:05:48 GMT 1 ricktop said:
2.6 published : - NEW live heart rate monitoring update (toggle on the double tap dialog box) - NEW integrated calculator and chronometer apps after app launcher with left swipe - NEW support Marco set skin command
Next bluetooth steady connection or calling feature or maybe a tasker or a reminder when the connection is off. Next SMS Messenger replay. Next NFC tag chip with an app I Hope for this just kidding LOL Xd
Really great good job
ricktop
Great update. Love the new features. So now Both agenda and HR are working for supporting watchfaces.
Hexagen watchfaces are working as they should again… Thanks.
HR works great in my kw99, tres cool.
One question, i noticed that the sort by name option first sorts the files alphabeticaly from A-Z and then from a-z
That means that for example Rickop1.watch and ricktop2.watch are not listed after eachother. Instead all other capitalized named faces get listed first.
This was also there in the previous version doewnload its not related to the new version.
I’ll also check in other apps, to make site it isnt related to my watch firmware.
Greets
Jul 29, 2018 10:50:58 GMT 1 ranja said:ricktop Great update. Love the new features. So now Both agenda and HR are working for supporting watchfaces. Hexagen watchfaces are working as they should again... Thanks.HR works great in my kw99, tres cool.
That means that for example Rickop1.watch and ricktop2.watch are not listed after eachother. Instead all other capitalized named faces get listed first.This was also there in the previous version doewnload its not related to the new version.
Greets
Yes sort is case sensitive. I could try to change it…
