Have you installed a widget already ?
Hello everybody, have a problem with the launcher. I cannot start data connection, touching the button doesnt do anything. Thor 4g is my watch. Thanks!
Edit: There is no option in the watch settings to turn on/off the data connection!!! How can this be??? I can do it ONLY from the default launcher shortcuts…
If I have the widget installed, then after the reboot is visible, but I can not added another. I can choose a widget, but it is not added. If I do not have a widget, after reboot, just like above.
Sept 7, 2017 13:23:04 GMT 1 ricktop said:
INTRODUCTION NOTE : This work is done for free. No one should take it to sell it or put on the PlayStore without my permission. If someone find this application useful, feel free for a little donation (not too little otherwise it's only for PayPal...) : Community Donation Page - goo.gl/FrUKUE donations for THIS project are welcome here : paypal.me/EricCROCHEMORE
Wow too much versions. The best version for H1 ?
Think, the newest one
ricktop
The test version you posted (2.6) solved the problem i had on my kw99 with widgets disappearing.
Strange thing is i never had the problem untilll i inserted a sim card.
After that widgets did not stick after enabling, and some watchfaces started behaving strange.
This test version works through, i’ll post back if i find anymore issues.
BTW nice additions, by right swiping from the apps screen. Very usefull.
Great workshop.
Greets
Kw 88.
I paste the .watch file into the clockskin folder and I do not see the dial. what am I doing wrong.
Jul 18, 2018 23:34:00 GMT 1 lisek702 said:
Kw 88. I paste the .watch file into the clockskin folder and I do not see the dial. what am I doing wrong.
Nothing, maybe this one is not supported. Make sure you follow the YT channel tutorial for this.
After second reboot is ok. I can add widgets.
Time still in Paris after updating it to Honolulu, rebooting and setting again. Dragging the slider to other locations also does not change the time. On Thor 4 stock updating to the beta has not relived this issue. I have not been using a sim card with it until to today. Still activating so maybe that will help.
I had to turn off the KW88 and when turned on again, I can not add widgets. Generally after each reboot I need to reinstall the Launcher and then it's okay for the next reboot.
I've found something that may explain your issue, i'm adding a correction in next release...
Ricktop thank for launcher. Open the application in the application menu. Exit application. Menu returns first icon. it will not return to the application icon. Is there a solution? sorry for the language.
Probably yes, but i’ve not worked on this… I’ll look.
ricktop
Hi ricktop,
I noticed that in the 2.6 test version the numbers in the watches turn to White instead of their actual collors.
It seems tot happen alot with the Hexagen faces i have.
I think 2.59 displayed them as they should.
I made a compilation screenshot with two examples. Top row is how they should look (picture taken in watchface browse mode)
Bottom row is how they actually look in 2.6.
Greets Aj
Great, I'm waiting
Jul 21, 2018 13:04:53 GMT 1 ranja said:ricktop
Hi ricktop,
Greets Aj
the problem is in the (type=ā€œtext_ringā€) command. this command has no color.
Hi ricktop,
Greets Aj
Right, there was a bug, it’s corrected now. Wait for next 2.6.   ;-)
Jun 29, 2018 3:51:09 GMT 1 kensupen said:
Jun 28, 2018 21:34:43 GMT 1 h5 said:
Thanks kensupen, but I am not sure that I know what you mean by "download". When I click on the faces you posted it only brings me to the image, not to the download link.
How can I download your faces?
Sorry about that. When I edited my post, it removed the link.
Download
Hello kensupen,
I tried your faces and they would be great if they would work. One problem is that it actually does’t change from AM to PM. Then at 8 PM, the clock resets to 0 hour.
But the first part, the AM works. Can you fix the rest?
ricktop
Hello, ricktop, thank you for your work, the app is great: I’ve just installed the launcher on my new Lemfo Lem5 pro, and I’ve deactivated the default launcher, and it runs very well.
I have only few problems:
  1. ā€œHand bright screenā€ button does not work, because if I turn it off, the screen still wakes up when I turn my wrist, what can I do?
  2. When I click on ā€œairplaine modeā€ it shows a message of error ā€œunfortunately, Settings has stoppedā€, how can I fix it?
  3. Sometimes the widgets I’ve created (when you swipe from down to top) disappear and I have to re-create them
  4. Is there a gesture that allows me to open the ā€œrecent appsā€ function, to kill them?
    Thank you
