Eric your launcher is so good that maybe you can give the permission or be part of the team of the open watch project , think about it it would be great addition for the project.
What do you think?
Jul 29, 2018 12:41:28 GMT 1leafar said: Eric your launcher is so good that maybe you can give the permission or be part of the team of the open watch project , think about it it would be great addition for the project.
What do you think?
I've no problem with this, as long as it's a free project and that permission has been asked.
Hi! How to put the “Universal Launcher” as default again after clicking the Uninstall option. Already tried to reinstall but without success. Using version 2.6 with Lemfo Lem5. Tks!
HI! I’m on the latest 2.6 on my thor pro…is it possible to downgrade to the previous one? this last release drain too much the battery. 1hr 10%…the previous one was 1hr 1-2%
Jul 31, 2018 7:14:25 GMT 1davefraud said: HI! I'm on the latest 2.6 on my thor pro...is it possible to downgrade to the previous one? this last release drain too much the battery. 1hr 10%...the previous one was 1hr 1-2%
All previous version are on first post. But this version doesn’t drain more except if you activate the HR. Maybe you’ve changed something else.
Jul 30, 2018 22:11:20 GMT 1grayson said: Hi! How to put the "Universal Launcher" as default again after clicking the Uninstall option. Already tried to reinstall but without success. Using version 2.6 with Lemfo Lem5. Tks!
Starting the launcher and pressing the power button will trigger the default launcher question… That’s strange.
All previous version are on first post. But this version doesn't drain more except if you activate the HR. Maybe you've changed something else.
Thank you Ricktop.
Ive changed nothing and heart rate it's off...i don't know what's the problem but the drain its more than before...
Jul 30, 2018 13:11:16 GMT 1mcwone11 said: Hello, a question why does the screen take so long to turn on when the power button is pressed? Thank you
Be more specific, there's no delay on my watches.
Hi, I’ll explain, when I press the power button to see the time with the launcher stock the screen turns on instantly but with the universal launcher when I press the power button to see the time the screen takes to turn on almost 1.5 seconds is like if the launcher stays in a kind of lethargy and for that reason it takes to react. I hope you have explained me well … Thanks
It’s clear, it’s instant on most watches, so maybe yours is not like others…
I tried your faces and they would be great if they would work. One problem is that it actually does’t change from AM to PM. Then at 8 PM, the clock resets to 0 hour.
But the first part, the AM works. Can you fix the rest?
Can you tell me what face you are using? Also, is your watch set to 12 or 24h?
Hi kensupen,
I am using 3 of your watch skins - same issue with all three: LCD bezel, LCD lines bezel, and LCD lines. Unfortunately, I do not see how to change my watch H5 from 24 to 12.
Also I like Lines 2, but not the dotted display of the hours.
