It's a Lemfo Les1, the healt app on the watch give the ammount right but if I use a .watch skin with a pedometer on it adds the ammount from the previous day.
It looks like if the watch is shutdown and the date changes the pedometer option wont reset to zero if the watch is restarted.
Also a older version of the launcher doesn't have this problem, so it's still looks like a bug in the launcher.
Have you seen the other bug report? I post it on this tread about widgets that disappear?
Same problem with Q7/S1 watch steps are still there after restart, also if I change the watch face.
Oct 19, 2017 7:17:57 GMT 1nameless said: And pedometer works? If not try restarting watch. Sometimes sensors get stuck and only way out of this is to restart it. Sometimes couple of times. Seems like a kernel bug cause I only seen it on earlier firmware versions
Same problem here with the pedometer, I shutdown my watch every night and restart it it in the morning and then the pedometer still adds the amount from the day before.
I don't think it's a kernel bug because this only happens with this universal launcher from Ricktop, It's just a bug in the launcher.
I think these are unrelated things. gdisckaraoke had issues with not working wrist gesture. If pedometer is not working at the same time it means sensor is not working or reporting any values.
In your case pedometer works just reports odd values. Just to be sure you areusing latest version right?
Oct 19, 2017 8:48:08 GMT 1daveth said: Same problem here with the pedometer, I shutdown my watch every night and restart it it in the morning and then the pedometer still adds the amount from the day before.
I finally managed to fix the wrist gesture issue but I had to uninstall the clockskin launcher and reflash the firmware
If itās just one skin that does this, try the reset skin button After the double tap.
Oct 19, 2017 12:58:35 GMT 1daveth said: It's a Lemfo Les1, the healt app on the watch give the ammount right but if I use a .watch skin with a pedometer on it adds the ammount from the previous day.
No difference, every skin with a pedometer on it has the same problem.
A other user (hans65) on this topic report the same problem with this version.
Just to make sure I have the latest version (I did install it but maybe there went something wrong) where can I find the version number which is installed?
Iāve already uninstalled the old version (2.3.3) re-installed the new version, still the same problem. After the steps Iāv powered off/on the watch, still steps in the watch face. I changed the watch face to an other one with pedometer function, same amount of steps like the other one.
Not my intention to pile on but I canāt seem to get the launcher to work very well in my I4 Air. Iāve tried the newer versions including the latest. I also went back to 2.2.7 with similar results. Sometimes the notations page will come up when turned on instead of watchface. Sometimes I get a black screen and have to reboot to fix it. I usually just go back to the Main Activity launcher that works ok.
captjon when you get the blank screen, have you tried to swipe down and then swipe to the left 'till you see skin preference? If this works for you, press then skin preference the launcher crashes then (it does on my watch. After that, Iāve to select it again and it works. So you donāt have to restart the watch.
ricktop , Just what I thought it only happens when overnight the date changes and the watch is off.
Last night I let my watch on and the the pedometer reset to zero (like it supposed to do).
Now you can reproduce this bug and I hope you can solved it.
Bug 2) As I mentioned earlier the widget are also something strange with it (and only when shutting down the watch over night), the widget (some of them) disappear and become a black screen with a white small circle in the middle.
And sometimes the widget switch with a widget I deleted before.
Bug 3) After making a widget a lot of time I canāt scroll back to the watch face, after push the button on my watch and reactivate it work again.
Oct 21, 2017 7:32:59 GMT 1daveth said:ricktop , Just what I thought it only happens when overnight the date changes and the watch is off.
Bug 3) After making a widget a lot of time I can scroll back to the watch face, after push the button on my watch and reactivate it work again.
Yes did as you said and reproduced the bug, and iāve found this stupid little bug !!
For widget itās an Old bug, but never found a solutionā¦
I am newly user for my lemfo lem5.
I had installed your universal clock skin launcher many times. But I still got an error, where the skin was placed un-centered, a bit downward right.
I tried to read many posts, but couldnāt found a clear answer to this problem.
Is there any solution for this error. Please help me.
You mean you tried to add it and it doesn't work, or you don't know that clicking on the + sign on the launcher widget part will permit to add widgets ?
2.3.5 published with only this bug solved.
After uninstall the previous version and installing the new version, the .watch skin give me a step amount of 39758 but the step amount on my healt app says 8488 (the step which I walked today), is this something which gonna be right overnight when the date changes?
