Have so many clock faces, would be nice to create 1 level of folder inside clockskin folder, shows up when you slide through faces and touching goes in. For example, holloween, xmas, digital, analog, movingpart. one level is all that is needed, if I had more then one say analog folder I would create ananew, anaold, anarolex, etc. I have to scroll through hundreds of faces to get to desired face. Thanks, larrykabo@gmail.com
just installed 2.3.4, major problems with animation, jerky like 10fps, the face with the subway train shows only the clockface on black background, second hand moves ok, went back to 2.2.7 a ok. LEM 5
Thanks Larry
just installed 2.3.5, animation all is good, I feel safe now I can get on the subway.
Oct 23, 2017 22:04:15 GMT 1 larrykabo said:
just installed 2.3.4, major problems with animation, jerky like 10fps, the face with the subway train shows only the clockface on black background, second hand moves ok, went back to 2.2.7 a ok. LEM 5 Thanks Larry
You could accidentally switch to dim mode. In that mode animations are forced to 5fps IIRC. When you double tap look just above the scale slider. Tapping on bright mode switches to dim and vice versa. Also .watch skins might display only some parts while in dim mode (depends on what skin's author decided when creating it)
Oct 23, 2017 10:45:26 GMT 1 daveth said:
After uninstall the previous version and installing the new version, the .watch skin give me a step amount of 39758 but the step amount on my healt app says 8488 (the step which I walked today), is this something which gonna be right overnight when the date changes?
Yes. Itâs old bug without solution. After midnight when step counter resets all will be good.
This happens sometimes when launcher crashes or after installing.
Have to admit that I havenât seen this in quite a while
ricktop, Still the same problem, the new version didnât solved this problem.
After turning on my watch this morning the step counter on the watch skin says 45963 steps in stead of 0.
Hello, I have one question. Weather forecast or sunset/sunrise is working or not? On my K9 (X3) Android 4.4. Only show today HI/LO teperature, current teperature and location, but on sunset/sunrise show ânullâ or. Same for wind data.
Hope you dont mind me jump in with a different problem (No.1 D5+): Suddenly no possibility anymore to make Universal launcher the default launcher. Deinstalled the universal launcher en installed it again, but at starting the app I dont get the question to choose a default launcher.
Universal launcher starts and works, but every time after turning of the screen the original launcher is back again, and I have to start the universal launcherâŚ
Is there another way to change the default launcher?
have you uninstalled the launcher from there own menu (last page)? If this is done, uninstall it from the normal app menu (in the settings from your watch)as well.
Can someone tell me how to get the heart rate app working with the watchskin launcher on the Lem5?
Or is there any heart rate app that i can install to replace the stock one?
Oct 23, 2017 10:30:25 GMT 1 ricktop said:Oct 23, 2017 9:33:49 GMT 1 kotana said:
Work like a charm but it's possible to add other widgets? I really like this widget play.google.com/store/apps/details?id=prox.lab.calclock&hl=en but dont know how to add it. Will be perfect if it can add third party widgets.
You mean you tried to add it and it doesn't work, or you don't know that clicking on the + sign on the launcher widget part will permit to add widgets ?
Yes, I did click on the + sign but on the options choose widget, this widget doesnt appear:(
Oct 25, 2017 2:31:53 GMT 1 kotana said:Oct 23, 2017 10:30:25 GMT 1 ricktop said:
This widget requires a Google calendar.
Wallpaper, not sure itâs compatible with the watch Android version. Tested successfully on one of my watches⌠No bug on the launcher.
Thank you for your reply,
I did this, but unfortunately no change. Still no option to choose the default launcher anymore.
Oct 25, 2017 10:07:59 GMT 1 kras said:Oct 24, 2017 20:57:24 GMT 1 hans65 said:
Normally using the âExitâ button of the launcher setting should trigger the Launcher default choice. So, strange behavior of your Android probablyâŚ
Oct 25, 2017 11:08:25 GMT 1 ricktop said:Oct 25, 2017 10:07:59 GMT 1 kras said:
Thank you for your reply, I did this, but unfortunately no change. Still no option to choose the default launcher anymore.
Normally using the "Exit" button of the launcher setting should trigger the Launcher default choice. So, strange behavior of your Android probably...
I am affraid so. I was only hoping the default launcher choice could be set another way. If I find a way I will post it. May be some one else encounters the same problem.
Hi, I want to use this launcher but is it possible to move some of the original Lemfo LES 1 Watch faces there? There are a couple that I like very much and want to keep.
Thank you
Hi great RICTOP, thanks a lot a lot for this wonderful launcher. Only one suggestion⌠sometimes screen display by clockskincoco unintentionally wakeup asking to change de skin. To change skin on stock firmware, we have to put finger and keep it for some seconds, ok. Would be possible change this function for something like it ?
Oct 25, 2017 7:27:21 GMT 1 ricktop said:Oct 25, 2017 2:31:53 GMT 1 kotana said:
This widget requires a Google calendar. Wallpaper, not sure it's compatible with the watch Android version. Tested successfully on one of my watches.... No bug on the launcher.
Thanks for your reply, I already remove stock calendar and install google calendar but it still not appear. I see some app the widget can appear but some it doesnt (Even I tested with my phone and it appeared) . Maybe because of the version of Android of my D5 No1 (4.4.2). Anw thank you so much
Cant understand wrist settings⌠It just stopped working.
Hi Ricktop, I factory reset my LES1 watch and changed clockskin version from 2.2.0 to 2.3.5 and now I have a few skins that wont open? I can see the previews but when selected the watch screen goes black. Double tap and the preview is there again and I can scroll to select a working skin
A couple of examples now not working Lego_ARPv2, Electricity_MeterKW. no error logs
