Even steam and waze widgets does not work
Eric, big thanks for new version. Almost everything looks here O.K. on different skins ( so far tested), including widgets and notifications on I4 Pro.
One problem is with steps counting. Now the amount of steps doubles on each reboot. Can’t get actual value, which is in Health app
Can You fix this?
MERCI!
Sept 7, 2017 13:23:04 GMT 1 ricktop said:
Hello Erik thanks for this beautiful launcher. Have tried him, but I'll wait for a while, till you've also linked the heart monitor. Thank you Roel.
Thanks so much for your hard work Eric. I really appreciate you uploading this latest update to the Play Store. Now I don’t have to check the web site regularly and do manual updates. I can let my watch do all the updating automatically now. I still think you should start charging a fee for the launcher, even if it’s just $1. You’ve worked really hard on this and deserve some compensation.
Thanks so much for your hard work Eric, I found it in play.google.com. I will follow you on. sorry again I use google translate
Oct 12, 2017 16:10:13 GMT 1 nixus said:
Eric, big thanks for new version. Almost everything looks here O.K. on different skins ( so far tested), including widgets and notifications on I4 Pro. One problem is with steps counting. Now the amount of steps doubles on each reboot. Can't get actual value, which is in Health app Can You fix this?
Right, something gets wrong with steps. I'll look at it.
HR is not standard, so best is to use the HR App or widget from the launcher. HR will not be integrated.
Oct 12, 2017 10:28:46 GMT 1 mtibee said:
Am I the only one who has trouble with the notifications? (Only the watchface appears when the watch (DM368) gets a notification.)
No, you are not. I have these problems with notifications on DM368 for more than half a year now, but Rick cannot reproduce this problem on his smartwatches (= other than DM368) ...
Oct 12, 2017 22:37:49 GMT 1 stevef said:
Thanks so much for your hard work Eric. I really appreciate you uploading this latest update to the Play Store. Now I don't have to check the web site regularly and do manual updates. I can let my watch do all the updating automatically now. I still think you should start charging a fee for the launcher, even if it's just $1. You've worked really hard on this and deserve some compensation.
I cannot find it on the play store. What's the app name?
Check the first page and click on the link there.
Thank you, it is much more easy this way
Universal Launcher New Gen
Oct 10, 2017 16:00:26 GMT 1 cojackck said:
www.dropbox.com/s/dowhjiwbqiqat2y/gold-kojack-copy.watch?dl=0 this is an example watch -marker and numbres does not change color on the watch -the month number is a gradient color, on the watch it is static color -the word WATCH MAKER and the 2 lines are gradient color and shows a gradient color but not in the right angle on the watch the snow image is not moving on the watch. thankssss
Correction is on its way for next version…
It works fine in my K9 3G. Fantastic!!!
A new universe of options.
Hello Eric,
some People have Problems with your launcher on the Finow x5 air, i have some of this Problems, the first big Problem ist the launcher is not in the Center, the round or square opption in the Settings on the watch have no effect, it is impossible to uninstall the launche you have no Change to find the buttons.
Maybe it is a Problem on the Firmware, the Firmware on the Finow x5 air ist 170825-1503662607.
thanks
Change the dpi and everything is fine
Ricktop, It’s a real great launcher you made, and I made you a donation to you for the good job!
Can you explain to me what the buttons in the menu (when you scrol up from the clock face and then the 3e screen) the button next to DPI, if I click on it the text says Default or Zoom?
What ever I select nothing happens?
Oct 14, 2017 14:52:55 GMT 1 daveth said:
Ricktop, It's a real great launcher you made, and I made you a donation to you for the good job!
Thanks for donation.
This menu is for square zoom or normal. It only works on some finow i think.
Oct 14, 2017 12:49:27 GMT 1 ernst said:
Hello Eric,
thanks
I use the launcher every day on my X5 Air, never seen this centering problem... To uninstall, click the uninstall button of the launcher 3rd setting screen.
