First TWRP 3.0.3 recovery port for IQI I4 with multi-language support.
Requirements I4 must have firmware v20170322
SP Flash tool must be a newer version, I use the v5.1628
*** WARNING *** DO NOT APPLY any OTA update after you have flashed this recovery! This could (soft)brick your watch.
OTA updates require stock recovery.
Notes Stock I4 ROM includes a service which overwrite recovery partition if it’s different from the stock.
To overcome this issue I included also a patched version of the boot.img from the v20170322 ROM which is exactly as the stock version but the recovery overwrite service is disabled.
The included scatter file is modified to load both the recovery and the boot image files; no changes to partitions layout are present.
Installation To install, use the usual procedure for flashing the recovery with SP Flash Tool. Don’t do it if you are not 101% sure of what you are doing.
Usual disclaimers apply *** I am not responsible for anyone’s issues here. Use this at your own risk !! ***
Load the supplied scatter file in SP Flash Tool
Make sure that no other other files is selected, ONLY boot and recovery must be selected, and press “download”.
Power off the watch and then connect it to your PC and it will flash in few seconds.
I’m interested in buying a IQI I4 PRO, and would like to try and build things for it, starting with TWRP, as i did for some other device.
Would this recovery work on a i4 pro ?
Do you know which device tree was used to build this recovery ?
It works for all the I4 models that I have tested
Just follow what Ciro has written.
Use the custom boot image first with the recovery he made. Flash super su. Then flash your original boot image back to the watch.
Done.
Done.
Ok thanks. From my android rom experience, i suppose the “self reinstalling recovery” problem is related to recovery-from-boot.p file and its flashing script in /system/etc.
But that was not the main question : I’m a developper looking for a new device to play with, so I’m only interested to know with which device tree this was built, as I couldn’t find it on GitHub.
Done.
Jan 28, 2018 10:16:47 GMT 1pix106 said: Ok thanks. From my android rom experience, i suppose the “self reinstalling recovery” problem is related to recovery-from-boot.p file and its flashing script in /system/etc.
plz the H2 from microwear:)
I like the sobriety of the i4, and the 2GB ram of the i4 pro.
H2 is too thick imo.
Are there any sources available ?
So much questions
Thanks !
Just a message to mention Ciro Danise, to see if he knows where to find sources for TWRP on i4 pro.
No hurry, i don't have the smartwatch yet... but it's a matter of days now
I don’t know what can be built, what i can build… I have already built CyanogenMod for a MTK tablet, with some luck involved
You can install the TWRP of this thread, root your watch with SuperSU, then follow the instructions of THIS post to restore your current boot.img[/quote]
See this post? Ciro already posted it.
Jan 29, 2018 21:56:21 GMT 1RASC Moderators said: You can install the TWRP of this thread, root your watch with SuperSU, then follow the instructions of THIS post to restore your current boot.img
We’re not talking about the same thing : I’m not trying to install this recovery, nor asking how to root the smartwatch.
I’m a developper, i’d like to build/compile TWRP from source for the i4, and maybe afterwards i’ll try to build a rom for it (i have already built TWRP for a few android tablets, and a few roms for one of them)
To do so, TWRP sources are needed (no problem there), with some other sources to build it for a specific hardware (device tree).
As you told, and as i could read , this recovery is working => that’s why i’m asking which I4 specific sources it was built with.
I suppose, as he posted it, that Ciro Danise has built it himself, or knows more about this.
If you just want to build TWRP, you can use a generic device with the watch_mdpi theme and then add the prebuilt kernel from the boot image.
This is how it’s usually done because of the missing kernel source.
Jan 29, 2018 23:39:15 GMT 1Adios said: If you just want to build TWRP, you can use a generic device with the watch_mdpi theme and then add the prebuilt kernel from the boot image.
This is how it's usually done because of the missing kernel source.
ok thanks ! A few tweaks are needed to adapt the fstab to TWRP, if it is still needed (i saw in the "recent" commits that it could now read multiple fstab format), and a few other tweaks can be added to mark which partitions are to be backed up etc...
Anyway, i’d like to see the device tree that was used for this TWRP : if i may, and if i understood it well, publishing the source is mandatory to comply to GPLv3, which is the license used by TWRP.
Jan 30, 2018 18:55:11 GMT 1pix106 said: if i may, and if i understood it well, publishing the source is mandatory to comply to GPLv3, which is the license used by TWRP.
That's right, but beside the theme (which seems customized) the core function will be pretty much identical with the BoardConfig i posted.
For TWRP only, there are no extensive device configurations needed.
Everything that is more advanced will necessary require the kernel source, but no (small) chinese company will ever provide those, as even big companies like Xiaomi struggle to comply.
