TWRP 3.0.2-1 for IQI I2 / Zeblaze Blitz First TWRP 3.0.2-1 recovery port with
First TWRP 3.0.2-1 recovery port with multi-language support.
Requirements
SP Flash tool must be a newer version, I use the v5.1620
WARNING
DO NOT APPLY any OTA update after you have flashed this recovery! This could (soft)bricks your watch.
OTA updates require stock recovery.
Notes
The recovery itself is the same for both the I2 and the Blitz, but they have different partition system so they require different scatter file. I have included the proper scatter file for each watch, DON’T use the wrong scatter file.
As the Lemfo LEM3 watch is (supposedly) the same watch as the Blitz, the recovery and the scatter file for the latter should work fine on the first, but I can’t test it so I can’t suggest you to use this recovery on LEM3 also.
The recovery could work even on the KW88 watch BUT there is an unfixed issue with incorrect display rotation, so I advise you DON’T use this recovery on the KW88 watch.
Installation
To install, use the usual procedure for flashing the recovery with SP Flash Tool. Don’t do it if you are not 101% sure of what you are doing.
Make sure the option “Download only” is selected.
Usual disclaimers apply I am not responsible for anyone’s issues here. Use this at your own risk !!
After the flashing is completed, reboot your watch to access the new recovery by using the “adb reboot recovery” command.
Downloads
TWRP 3.0.2-1 for IQI I2: https://goo.gl/Ltx1FR
TWRP 3.0.2-1 for Zeblaze Blitz: https://goo.gl/9Y2k2D
Fantastic mate :+1::+1::+1:
Thank you @Ciro_Danise ​…We want cyanogen porting!!!.. Are you working about a ROM?
We can make some improvements but we don’t have the source code to be able to go that far…
So kingwear will not supported?
Kingwear will be supported when we find the fix for the rotated screen issue.
@Ciro_Danise described as unfixed problem
@George_Zervas On KW88 TWRP recovery the display appears upside down, while the touch panel is correctly oriented.
@Ciro_Danise
lem3 my work about 15 minutes . itself off and not working does not help . I thought about a hardware reset but even dumb describe how to do it . link https://www.youtube.com/watch?v=GzqETmXGPZQ&feature=youtu.be pls help
Awesome work mate! But a dumb question… In the end, we don’t need it, right? Cause shitty policies don’t release the code for people to develop
@Jorge_Fernandes
well - yes we do need it to flash modified system images and take backups. Not to mention good, clean root access.
We have managed to achieve some pretty good results even without source code :slight_smile:
Yes, sure, not my intention to be a hater or ‘persona non grata’! Just trying to enter the “system” and be more aware of the development.
As i said, that was a awesome work, and i trully agree with u, even without the source code, great progress has been made.
I’m still waiting for my zeblaze, is taking so loong i just cant wait xb have been in this forum last week achieving some knowledge, thanks to all of u!
@Jorge_Fernandes
hey dude - it’s all good :slight_smile: No worries
Scusate la domanda. Sono un po’ ignorante in materia, a cosa serve questa applicazione? Ho appena ricevuto un zeblaze blitz e ho notato che non è possibile usare la parte audio ,(microfono e altoparlante) per effettuare chiamate quando sono collegato in bluetooth al mio Huawei g7. Possibile che nonsi possa utilizzare in questo modo?
@Andrea_Matteoli This application is a recovery tool. If you don’t know what it is - don’t use it. It is complicated and really for users who understand the Underlying properties of the Android operating system.
The bluetooth audio issue is because the watch does not support making calls while paired to a phone.
Capito, ma secondo te non risolveranno mai questa mancanza? Ci sono smartwatch che costano la metà e hanno questa opzione, se losapevo non lo compravo…
@Andrea_Matteoli 1- Ti sei accorto che questo è un gruppo in inglese? Perché continui a scrivere in italiano?
2- This post is related to TWRP recovery for I2 and Blitz, your questions about bluetooth pairing should be done elsewhere, in the proper sections.
Thank you
Perché non conisco l’inglese
I apologize to you all for using the Italian language for this answer to an Italian friend.
@Andrea_Matteoli Il problema che tu segnali relativo al pairing bluetooth è stato discusso varie volte nelle sezioni General discussion e FAQ ed è solo un problema software che i produttori al momento non vogliono/possono risolvere, ma forse in futuro potrà essere corretto con qualche sviluppo dagli utenti o dai produttori stessi.
In questo post si discute della recovery TWRP che è, come sugli smartphone, se hai qualche conoscenza del mondo Android, un tool di basso livello per facilitare il root, per fare il backup, il reset, l’istallazione di software non ufficiali e altre funzioni avanzate che normalmente servono solo agli utenti smanettoni.
Spero sia chiaro e continua a seguire questo gruppo che presto o tardi il discorso bluetooth potrebbe risolversi.
Good job Ciro… Thanks…
