Some questions:
I see in one of your images the memory amount in the watch. If you add the partitions, 16Mb+945Mb+982Mb, it is not 4Gb. Do you know where is the rest? Is there another system partition or so?
I would like to wipe the my battery, because the watch switches off with 90%. Could I make it with this?
Thank you for your great job!!!
@Javier_Valero There are some other partitions (e.g. preloader, lk, logo, cache, recovery) which are not included in that list. Also, you see the used space of the listed partitions, not the size.
Wiping battery stats, if you are looking for this, can be done with “File manager” under “Advanced” menu of the recovery.
@Lukasz_Dyrcz It does not work for this model?
Thank you so much! Which version of supersu would work after that?
How can we enter twrp without pc? Is there any combination on boot?
No combination on boot, sorry.
If you root your watch, then you can use various app for rebooting in recovery, e.g. Mobileuncle Tools
ah, thanks! I was using “adb reboot recovery”, but I wanted to switch usb debugging off, so…
so it works on IQI launch i2? you can have the root of the smartwatch? It is thanks in avance. The process can be reversed?
Hi. i2 iqi have a smartwatch. I would like to flash the TWRP but I wonder what is the process for the flash tool recognizes the clock. It has to be switched off and plug the USB or watch on? Thank you
@Silver_Sm you can swap TWRP and boot.img before you flash them
Then the watch would enter recovery when you start it and you can press reboot recovery inside of the recovery to boot Android
Please take for iqi i3 stock recovery and trwp recovery
IQI I3 TWRP recovery is available on the Round Android forum, here:
http://roundandroidwatches.proboards.com/thread/901/twrp-recovery-kw88-dm368-version
My blitz its on, but my screen its only black and never star the sistem why? any people here can hellp me? My watch its new 2 weeks ago
@carlos_garcia_garcia go the forum for technical questions
@Ciro_Danise not work for i3, not access twrp. access recovery stock. help! my smartwatch is i3-v07-201703… iqi i3 512mb/4gb
