@legiona3r
The link is posted earlier in this thread.
If you send me a request to access it you need to use the email address which you joined this forum with. p###$##@outlook.com
I hashed out your real address.
It does not have to be a Gmail account.
If you use a different address you need to quote your user name for the forum and your original email.
It makes life a whole lot easier if the email address is different to your forum email address.
Flashed watch successfuly thanks for A10 animation is amazing.
Hope watch will work fine
Glad you like it.
Seems to be working well
By the way seems watch started to work faster after flashing
You are using stock factory A10 Firmware or FAW A10 version?
Yep, that’s the factory stock A10 that was never released.
It’s pretty good for stock FW
Can’t connect to watch keep saying couldn’t connect because of incorrect password
Any idea what I am doing wrong?
Did you factory reset after flashing
but when watch goes to lock screen watch droid stops working how to fix that?
After flashing I cant find that optimising app
Its slightly different from phone to phone . Its not a app its in settings . Under apps you can find what apps are optimized and which are not . Uncheck watchdroid so it runs in the background
Found battery optimization.turned off from watch droid but still disconnecting when screen get lock
You have done this on the watch ? Yes
Also allow unlimited data access
I sent you another request from a gmail adress, the name is quite similar to the adress I use for the forum account. I also wrote the email for the forum and the forum name in the request message.
Can you tell why watch restarted itself?
Of course not… How could we possibly know?
You need take the time to get used to it and test it properly, or just go back to the previous version.
Permission management in Android 10 is very different.
Obviously factory reset if you go back. Same as when you flash any firmware
