You can upload to google drive and share the link. But the video won’t help, I guess.
Tells me I cannot share a link in the message…
Is there anymore LEMFO builds besides v2.0?
It’s because you are a new user. Should work tomorrow. Otherwise send me the link via PM, I will add it.
Do I have the option to sent PM’s? I’m not seeing any button for it even when clicking on your name
Yes, I can help.
Do you want LEM T or Ticwris Max?
However, I also need to know which firmware came with the watch before you flashed it.
The exact details if possible, I’m guessing that you made sure that you have the stock firmware that came with it before you started this journey…right?
Even if you just have the build version details, it will be fine.
Also, it would definitely help to see a video and you can upload it to your G Drive and post your link here as hxxps instead of https.
This will prevent it from being recognised as a Web link and will allow you to post it.
last I checked before flashing the firmware on the TicWris MAX was (ticwris_max_v1.8_20200619). Unfortunately, no, I didn’t make sure I still had the original stock firmware
- sure. here’s the video Zipped up. - https://drive.google.com/file/d/1BB5BEKItTH6DwEbSR-cu_J9s7hioWdRy/view?usp=sharing
I went from TICWRIS_MAX_V1.8_20200619 to TICWRIS_MAX_V1.9_20200713_20200712_072642 then to DM100_LEMT_V2.0_20200713_20200712_062848.. Which is now LEM T & still stuck at Android 7.1.1
There is only A7.1.1 stock firmware available for the DM100.
No A9 or 10…not even our FAW A10 firmware will work on the LEM T / Max / DM100.
If you are aiming to upgrade to A9 or A10, I can’t help unfortunately.
I’m not sure where you are going to get a different version of Android for this model.
The DM101 is possible to upgrade, but not the DM100.
There may be a custom rom out there in the wild, but we don’t have it.
Sorry.
No worries to that then. But how can I get the Google Play Store to work. I mean anything pertaining to “Google” won’t let me even get to the point of Signinig in. “Checking Info” and spins an spins and ends with “something went wrong”
did you watch the video I linked up?
Your link requires a permission.
I have seen this issue on A8.1 watches. I once tried for upto one hour until the watch finished updating google then the issue disappeared. Pain in the arse
Link has 100% approval - Thanks for letting me know.
I let it sit there for 2 hours total = update/during update/idle after update… nope…
Did it ever work on the other firmware versions that you have tried?
Have you checked that you have not wiped your IMEI number during flashing?
Have you used your Google account successfully on other devices?
Honestly, there are so many basic things to check before you go down to the technical sub layer of troubleshooting.
These questions I ask may sound ridiculous, but they are all part of the picture.
I have ever seen home Wi-Fi routers causing the issues.
Is the stock Web browser connecting to the Internet and you can use it to search pages, for example.
Oh, yea Google anything works great on my phones, laptops, Desktops…it’s just the TicWris MAX. do you have the original stock file I could flash it back to OEM by chance?
So the stock browser is working fine?
Its not related to Google and should be fine if you have connectivity.
Do you use Wi-Fi or cellular data…?
If I go directly to the WEB on the TicWris MAX…I can get into the play store no problem… it’s the APP itself on the watch. I finally got it when it allowed me to enter in my Email and Password… then spins and errors “something went wrong and your decision wasn’t saved” and I can’t do anything from there.
I just wanted to make sure that the stock browser (not Chrome but just stock) was able to connect with the internet and that you can browse the Web.
That’s all.
So, is your imei number still there?
You know how to check this right?
