It did not help to reject notifications or duplicate notifications.
You are using WiiWatch app on your phone?
Yes. I’m using WiiWatch 2.3.3 from google play.
UL works fine without having to play with DPI. Why do you have this need ?
Because all watchfaces (pre-installed and others) are displayed way too small, something like 3/4 of the display only, using the UL from Google PlayStore
Switch back to standard DPI value. Then goto skin preferences in the UL settings. Set scale value to 0% and save.
This has happened to me before and a reboot normally brings all back in order to correct size . Unless you have altered UL settings ?
Disable wiiwatch and install watchdroid. This is able to push all notifications to your watch without any issues. And it’s much more stable. If you do so, don’t forget to goto settings - more - backround Cleaner and disable watchdroid.
I’m using this watch since 5 days. And I’m using UL and watchdroid. Both are working perfectly on this watch.
Thank you very much. Watchdroid correctly shows and rejects notifications.
What is the universal launcher useful for?
Is it possible to set always display time?
It is a great app . My favourite also . You cannot have " always time " on the prime due to the screen . UL gives you different options like
Being able to use watch faces with animated images ( .gif files )
You can set the screen to permantly on
Add widgets
The benefits are great . Load it into watch and have a look
Permanently enable the screen on this watch is not recommended because it is not an AMOLED display.
Can I set edge visibility in applications? Third-party apps don’t help.
No. But you can use the square mode if needed. Press and hold the power button to enter the “power of” menu. Hit the upper button to enter square mode.
Thanks.
Do you know pages with skins for universal launcher? Besides this https://discourse.fullandroidwatch.com/c/round-custom-faces/universal-launcher-faces
Look on our main page ( top left hand corner ) . Thanks
Do you mean this page watchawear.com?
For this you need the WatchAwear program - Companion for WatchMaker Premium and WatchMaker Watch Faces and finally says that i need to buy premium.
No, he’s talking about THIS page. Goto menu - categories - round custom faces - Universal Launcher faces.
Ok, I know that. I thought there were other sites.
Search Google for watchmaker faces, also watchawear partner site has free watchmaker skins. And any skin from this site should work, not only special UL skins. That makes a lot of choice…
I muted the sounds in the universal launcher and can no longer be turned on because the button does not respond.
What to do?
Have you tried a reboot?
