Its not ota. You will have to flash it manually.
RK
RK
Did you read the other posts ? Good4life just wrote that he got v1.7B it as OTA.
I read a lot of the posts. I must have missed this one. I didnt receive v1.7B as OTA. I had to flash it manually.
RK
V 1.8b is not OTA. You have to flash it manualy.
That’s fine, I would settle for 1.7B, but update server says my 1.5B is up-to-date.
In what country are you?
Same thing to me
perhaps 1.7b only comes as an ota to those who already has 1.6b
I always have had connection error when try to update firmware.
Always updated with sp.
bye
Yes I had 1.7b in OTA after flash 1.6b manualy.
Well I don’t know this problem at the Kospet prime, but maybe you should try the app “No LED MTK”.https://androidfilehost.com/?fid=24499762635999486
If this doesn’t work, you can went back to v.1.6b.
I get it while wearing my watch on my arm. This would be a strange time to get a full charge notification, so I doubt that is it.
10 posts were merged into an existing topic: A short how-to about arraytype 100
It really a strange OTA function these watches have:
To get 1.7B OTA, you need to first flash 1.6B, 1.5B will never see the update.
I wrote to kospet for an explanation
Hello All,
I am looking for a new smartwatch (Current watch is a Samsung Gear S2). I have a few requirements and wonder if anyone can tell me if this Kospet Prime watch may fit the bill?
#1 I am left handed and wear my watches on the right arm. Can the Prime display be rotated 180 so the camera’s are positioned correctly when worn? If this is not a standard feature, then I did find a video which shows how to sideload an app which may be able to rotate a watch face and functionality. I don’t want to post a link if that is not allowed. If it is, I will be happy to though.
#2 I use the US Verizon Network. Does anyone know if the 4G Prime can work or be made to work with US Verizon?
Thanks so much
You can post a link, no problem at all. If you can’t post, the reason is that you are a new member. In this case, send me a PM with the link, I will add it.
Thank you. This video shows an app which allows for android displays to be forced to rotate: https://www.youtube.com/watch?v=ytSqbKSQuKE . I do not know this person or if this is possible on other watches but, I found it interesting and may be helpful to any LEFTIES (Not Leftist’s
