In settings / Plus / Application parameters
you can set the default browser
Thanks,pablo11 the video help a lot,because i put the watch on the charger in the on mode,not the off mode…
Flash work succesfully,but…after all the problem not solved.
After all settings,make a call,2 mins good quality,than again,i hear the partner voice clearly,but the partner hear just a grate voice,but not exatly like the old cable connected phone…
Is it possible,the watch microphone not 100% fixed,and when i use it,warmed up,and disconnect ?Because when i make second call after the problem here,the mic.make same problem,but when i wait a good 20-30 mins and make a call,can speak again 2-3 mins(because the connection point cool down,or what???),before the problem…
Someone have some suggestion???
Thank You for the time and answear.
there is no choice of search engine google
I checked the default options.
I checked the parameters of the search engine.
I do not understand why google opens others search engine for finalize my search
Do you need to use so many exclamation marks ?
why this question ?
Its regarded as rude when someone is trying to help you …
you don’t need much to be vexed
sorry it was not the goal
The Google app isn’t a browser, that’s why it isn’t shown in the list
Google chrome is a browser, also try Via browser
yes google and https . google chrome or google go and app ect .
in the watch there is a google application we see it in the uninstall option
no solution ok np, thanks for your help
Hi, I did mention the solution
You have to install Google Chrome or another browser
The Google app isn’t a browser, it’s a web service
the voice assistant opens google and google opens another browser. yes to go on the internet i can go with opera , google go and many others . its not the problem
I don’t understand your problem…
Before the google app can open google chrome, you have to install chrome. and then uninstall the standard browser.
the voice assistant opens google and google opens another browser . the défaut browser of watch .
the défaut browser of watch have problem left and right access angles , no possible use google assistant
google chrome is not compatible with kospet prime
…an other browser than WHAT?
I use google go . it is not possible use to by default
bad luck google go not work browser défaut .
I use the browser opera mini by default all work
from what I can tell, google go isn’t a browser. and you can download chrome from here:
https://www.apkmirror.com/apk/google-inc/chrome/chrome-79-0-3945-116-release/google-chrome-fast-secure-79-0-3945-116-android-apk-download/
Thank you for the link .
but cannot activate synchronization for my google account
