This issue has been a problem in most, especially round watches. I found the best solution, a year of so ago, to keyboard problems to be a small bluetooth keyboard. When you connect it to your watch, no on the screen keyboard ever appears. It is so much easier to type in the information and you have the full screen to work with. Mine is actually able to be mounted on your arm, if desired. I have no more issues entering passwords etc.
but I understood,reading in the forum ,to use only the download mode in falsh tools.
Sorry,why is better the upgrade option?
thanks
me too use nova luncher prime in my phone,so I’ve installed also in my watch and this is my face,and added more page to add all the widget I need.
thks
cool! I can see that you’re italian like me
what apps did you install for weather and battery ? also what is the icon on top left ?
hi yes,for the battery you can install a battery widget from play store,as you prefer.
The icon on top left is the mic recorder of the Prime watch.
The weather widget I used is this:
transparent clock weather
bye
Can anyone suggest me a good alternative of fb messenger? It consumes so much battery…i was texting for about 3 seconds with a friend and my watch lost 5% (with 50% screen brightness). I know about messenger lite, but i read that it lacks some features…
Used to be able to get Face Book lite app.
Not sure if it still exists but might be worth looking at it.
Thanks, i’ll try it
Hi,i have a problem.my watch dryed the battery when i make a call(i dont know how,because i charged it to 82%,and it must be 20-30% now).Put it on charger,and after 30 mins nothing happen.Put it on charger on pc,and i hear the volume of pc,when it connect,and after 2 sec. disconnect,than again connect,disconnect…i have disconnect,again connect,little move it left,right,etc. for sure the pins connect correctly,but nothing happen…what can i do? Thanks for help.
Clean all charging pins etc with small amount of alcohol . Maybe bad connection
Hey! Look for Maki Plus in the google playstore, it’s great on both phones and watches! It has dark mode unlike the Facebook app, messenger is integrated into the app, so you can do everything from just one app! The Lite apps does not work well on Kospet Prime, tested but uninstalled again. Good luck!
good morning, will not come out the update via wifi?
Thank you for your suggestion
I will keep it in mind. Now, I try messenger lite, as im not interested to browse facebook from my watch. I was pleased with messenger, the only problem was battery consumption.
All pins was fine,the thing happend again(see 413 post),but now when i put the watch on the charger,the watch lived up,and show the oem charge gif.
Okay,my watch make it again,and now i exactly remember things.Before i go out(now we have winter time,-2 celsius outside.),i look the battery percentage,its shows 32%.I use my watch like standalone phone,ALL not used battery dryer things(wifi,gps,blue.,etc)off basically.Okay,i go outside,drive the car 10 min.,then go in the bank15 min,then go out,start a call,and the watch go off…from 32% to zero % between 25-30 minuts??? I think last time (409 post)this happend again.My watch not show the true percentage,or what? Thanks for help.
I have had good success with running this battery calibration app on 5 or 6 different watches. You should only need to run it a couple times a year. The watch has to be on when you run the app. Its best if it is below 20% charge. Open the app. Hook up the charger and tap on the screen to start the charge. Leave it on the charger until it reaches 100% or it will not be properly calibrated.
HI,thanks for tip.I dryed the battery to 13%,thank make what you say.The app charged totally to 100%,than make a calibration automatically again to 100%.I hope this solve my problem,or must to learn to full customize the watch
Hello all
I just bought a Kospet Prime yesterday and having some issues
I use FAW as phone (sim card in) plus a Tablet, i downloaded Whatsapp on FAW and Tablet messenger on Tablet, is it the perfect combination? other suggestions?
I cant find any solution to enable bluetooth tether internet connection from FAW to tablet, can anyone help?
Is it useful to download watchdroid/Wiiwatch if my primary phone is already as FAW i/o a phone to smartwatch? if so, in my case, FAW should download Watchdroid and my Tablet download Watchdroid Assistant, do my concept wrong?
Anyway to magnify those corner button for easy touch, e.g. Whatsapp so difficult to click the voice message button…
Thx a lot
Hi . Here we go
1.yes ( but you have a sim in watch ? )
2. Explain more what you are trying to achieve
3. Only install watchdroid ( dont have both installed ) . Its the best
4. Try square mode or …
These above are best for watchdroid
In normal android phone Tethering section, we can choose bluetooth tethering, but in FAW, I couldnt find this option, only Wifi Tethering
I have one more question, how to go into hidden setting menu, like “accessibilty” as in android phone, i saw this once when i download watchdroid, but dunno any way to access to this menu.
