Its great with battery . I have screen always on with bt music as well
no mather what i do the sensor stay on i factory reset the watch and everythin i soon is the watch is power on the the green light stays on
That was it
Thanks a lot
Works fine
The only thing you can try is to flash the firmware .
@Dr_Andy_Vishnu is right. If this wonât help, itâs an Hardware issue, I guess.
Had my watch 2 days. Did a factory reset first off. Installed some apps. Turned off watch then charged for 12 hours WITH SIM COVER OFF JUST INCASE THERE WAS MOISTURE. At same time I charged earbuds and battery booster.
This morning installed Al Rods watch faces and a few other apps I forgot. Connected to computer to transfer music. Set up fully with mobile phone using watch droid. At this point Iâd had the screen on most of the time playing and listening to music and downloading etc. In otherwords hammering it. Battery at lunch was 40%. Quick boost from powerbank to 90 in about 45 mins. Went out for a walk picnic taken photos. Battery now at 57% full day (16 hours).
So pretty damn good
Thatâs not really had any battery training.
The watchface in full sunlight is amazing.
Only niggle I can find is the physical buttons are a little sharp. Some nice metal ones on G2 would be good
Not sure if this is related to Floating Toucher as I canât keep track of all these disjointed conversations, but in replying to Dr_Aâs apologies post of 5/29, itâs fine with me to post about the app. As for there possibly being multiple versions, that could be true. If any of you find one that automatically functions as the âProâ version, that would be great. All I have is the âfreeâ version which is limited, but after a week or so it somehow unlocks to the Pro version on its own, at least thatâs been my experience. I did purchase the Pro version before, but I donât know if itâs somehow checking the Play Store under my logged in account to verify that. I doubt it since the app and developer appear to be long gone from there. Anyway, Dr_Aâs post, my post, I think they are all the same. Sorry for any confusion.
Yep, thatâs your Google account activating the pro version if you leave network connected long enough.
Yes this thread is getting crazy.
The other thread with the firmware was intended to be for flashing and issues.
But itâs turned into a free for all crazy situation.
I will try to do something about it but Iâm up to my neck in dealing with many things.
Thanks anyway @SmartWatchTicks
I suggest if someone has the time and knowledge to make a FAQ/startup guide as a sticky in the genesis section of the forum.
As much as I have researched and kept up to date, it will be a real challenge to implement all the knowledge in this thread with once I finally receive my watch!
You have bought a brand new smartwatch and needs to be patched with duct tape? It doesnât seem normal to me.
A lot of people do this as a precaution only. Dont forget we all have a different opinion as to what amount of water - sweat should be acceptable . I have never used tape , i go running a lot and never had a issue
Jason from Kronos sent me here for some support. I have had the Genesis for a bit over a week, Thursday morning I wasnât paying attention to the power level and bottomed out the battery. I felt the vibration when it shut off. When I got home I placed it on the charger, the battery icon showed so I assumed it was charging. The next morning it wouldnât turn on and the battery icon shows but no indication of charging, occasionally the Kronos screen shows but it wonât go through its boot. Is there a reset or is this watch dead?
Did you use the dock or the USB cable??
I only mentioned this as an option. Some people may want to take the extra precaution until the source of a possible problem is found. I agree with Dr Vishnu and never use it myself. I mentioned the Microwear watches, because on the previous Round Android Watch forum it was a known fact that the Sim doors leaked a lot and we had to come up with ways to deal with it.
I agree, sweatproof and splashproof should be the minimum standard⌠I use to put Prime under the faucet, after I finish my workout.
both, dock charged but nothing to the watch
If splash & water proof are required, maybe use an eSIM in the next device.
I need to understand what people are doing here.
This has never been a problem.
Unless you leave the watch on the dock overnight with no USB cable attached⌠Because then the watch will charge and then discharge because all the power in the dock has been used.
The dock is designed for a portable backup power system. Short charge. You can use it for longer charging as long as it is connected to a power source.
It also has a little button on the top and if this is pressed it will stop charging.
If you are at home with a power source you should use the direct attach USB cable. Itâs always the best option at home.
this is only for precaution i never had any issues with moist either, apart from that these android watches never been known for excellent fitness watches , if you want a real good fitness watch buy a Garmin ,apple or samsung, then compare the price. and after that useabilty good luck to skype,fb,messenger,e-mailing, google assistance ,etc on a 300 up usd watch and most important for many even forgot to mention 2 cameras wow
Hi pablo agreed maybe there should be FAQ or some videos with easy to follow tutorials on the youtube linked to this site. i charged my watch twice on the portable dock from 40- 50 % to 100% without recharging the dock works like a charm .now im testing the watch how long i can go on both docks (portable dock and ear buds dock ) im already going since 1.00 am my time last night no sleep tracker , sim card inserted quiet mode since i woke up received 2 calls wifi on and listening to spotify all morning and im still on 29 % after 10,5 hours im sure i can cover 24 hours with easily both docks at hand and using it as a stand alone watch with at least 10000 steps walking a day IMHO EXCELLENT
