Also preferably use a USB3 connection, as it is certified for a higher current transfer.
If you use a USB2 connection on a front panel, the long cable line may cause a voltage drop.
Is there a update (more recent) firmware for this watch? it has all the same specs as the Lemfo Lem T/TicWris Max. Would like to try and flash. on my Lem T Thanks!!!
No, they don’t even produce it anymore.
Sorry
Just FYI, i was able to flash “system.img” to the Lem T. So far the first big issues is that everything is rotated to the left. Not sure if i can do something in settings about that, but im sure there is something in the build prop that can be changed if not in settings.
I really don’t understand why you would want to use out of date firmware on a different watch?
But whatever floats your boat I guess
Yes the orientation is different due to the different screen driver
It was more so to see if it would actually flash. Would love to see if there is an updated version of the firmware and flash it. And with that said, what can be done with the drivers or if possible to change the orientation?
Edit: It would it be possible to change ro.sf.hwrotation=0 to cause the orientation to change or am i WAY off?
I have no idea - but I doubt that a simple edit will do the job
yes, that should work. I think that is the way where only the screen is rotated and the touch part stays the same, so if you need to rotate that as well, you have to do it another way
Yes, and that is the issue.
The defined touch pattern and rotation are not controlled the same way.
By all means, there is no harm in testing.
Nope couldnt get the rom to rotate. It seems like its a much smoother running rom. If i can get this to work i may try to Frankenstein a daily driver, at least until android 10
