I’m using SP_Flash_Tool_v5.1352.01, run the flash_tool.exe as Admin
to flash you need only the Download Tab, select the scatter-loading file, select download only, connect your watch to usb port.
This is it.
This is it.
Sept 18, 2017 11:17:14 GMT 1 hans65 said:
I’m using SP_Flash_Tool_v5.1352.01, run the flash_tool.exe as Adminto flash you need only the Download Tab, select the scatter-loading file, select download only, connect your watch to usb port.
This is it.
Sept 18, 2017 9:58:52 GMT 1 gnr said:
Sept 18, 2017 7:11:32 GMT 1 soniasophie9697 said:
i used till now s health but it has great impact on battery life what weird only after i flashed the watch with the SW, the Gliderun is great but again big impact on battery (can you guys try them?) the Gliderun can automatically use the HR sensor of the watch the ONLY one which works great and it is activity tracker app which has everything, i contact the developer but nothing so far from him:/i use an old verion of sp tool never has any problems of flashing not always the latest is the best:) mine is v6.14
when you say to try to use health and gliderun…are these apps that you downloaded? or do you mean the health app that comes with the watch?
Gliderun is perfect it uses the builtin HR sensor BUT it has some big issues like battery draining and the padometer runs even when i drive contact the developer but no respond from him that is a shame because he wrote that no negative feedback and that he can be contact via email but nothing…
ok i will check…i use runkeeper app and no problem with the battery
Sophie’s file works perfect, here is the link located to download the flash tool
No flash over your files. Preloader depends if your watch was originally a S1, if yes then you could the preloader marked, if not (your watch was originally a Q7) then unmark the preloader
Yes OTA is working
Sept 19, 2017 7:32:15 GMT 1 hans65 said:
Yes OTA is working
Yeah, OTA still not working for me. Says Root has been detected, cannot update thee device. Current version S1-149439-2252
Version it was giving me to update over OTA was 150355-8769
ugh
On another note will try those health apps.
to akisha:I know you wrote all ready your device is not rooted, but try to install FlashFire from play store and check the message from this app. If it still not working do a factory reset.
to gnr: here is the firmware I’m using ufile.io/uldet try this one and pleas keep in mind
start the flash tool, press the download button AND THEN CONNECT YOUR SMARTWATCH TO THE USB PORT
otherwise it is NOT working
no, S Health because i have it on my phone so that way it syncs with my watch but after the flashing battery drains faster with this app same with Gliderun, can you plz check with your watch?Gliderun is perfect it uses the builtin HR sensor BUT it has some big issues like battery draining and the padometer runs even when i drive
hi, these apps are draining my battery as well but not as ddramatically as yours seems to be
Sept 20, 2017 7:26:53 GMT 1 hans65 said:
to akisha:I know you wrote all ready your device is not rooted, but try to install FlashFire from play store and check the message from this app. If it still not working do a factory reset.to gnr: here is the firmware I’m using ufile.io/uldet try this one and pleas keep in mind
hi its still does nothing…must i format before flashing?
ok i will wait because i am a bit lost here!!!
don’t even know how to check imei
ok i just read that it is the sim card info…i have no sim card installed so i should be ok
