S1 smart watch
hello,
s1 watch stuck on android logo and won’t boot
please help
thaks
Sept 8, 2017 23:45:46 GMT 1 gnr said:
hello,
please help
thaks
how did it happen?
anyway this is the link to the FW: drive.google.com/file/d/0B7RSRLeb3rUfZlo4b3lpWFMxNTQ/view?usp=sharing
i added watch faces then deleted my clockskin file and lost everything
how do i use the files
thank you
thanks
thank you VERY MUCH my watch is now fixed!!!
everything is ok but i can not upgrade version…it downloads but does not install,gives error not very clear but i think its says somrthing about being rooted
not sure if it says root
frist, remember when you want to change watchface or delete you must be on a stock watch face, secondly, yes, i get the same msg about the update it seems the problem is with the servers and not with the watch. it can’t be rooted because flashing the FW delete any root that exist.
ok thanks again…so i guess we wait!!
yes   just weird that i flashed my watch so many times and was able to update and now it says up to date so i guess means waiting....
thank you very much for your help…i was about to buy another watch.
you made me save money!!!
if someone has a solution (if there is a solution) please help…still can’t upgrade
What version of FW do you have currently installed?
S1-1494392252
I think this is the actually FW
w626_l.s1.common.72.emmc.wg.s.170510.flash
it is in the link from soniasophie9697 have you flashed this?
yes
has anyone else had this problem?
Hi Guys, got a S1 watch. Already went thru the Android logo predicament after installing some watch faces, which weirdly resolved itself when I let it drain the whole day.
My new predicament is that I changed the screen resolution on developer options and now screen is unresponsive. I downloaded SP Flash Tool, Drivers, both Q7 and S1 firmware.
My question is do I have to Format Whole Flash except bootloader before loading the firmware or should I just go ahead and follow steps directly to download all checked boxes?
At the end, will flashing revert the modified developer option - Screen resolution?
Some orientation will be much appreciated. Watch was working perfectly fine, it was my curiosity that killed it.
My watch is charged, off, secured to cable, ready to be connected and get it back to life!
Thank you
Thank you
when you flash it the preloader will be marked and i should be if you use the FW of the watch but you do’nt mark the preloader when you use FW of different watch. reset the watch before you falsh even though it erase everything when you flash it. you need to choose download only.
Thank you for your answer.
Ok, I’m gonna choose the S1 firmware w626_l.s1.common.72.emmc.wg.s.170510.flash provided on this thread.
Select all boxes
Download only.
Good luck to me, here we go.
