I’m currently having issues trying to update firmware on the device. if i’m resetting the device to stock all i need to do is follow these instructions? or am I missing a step?
so far I follow the instructions. and hit the green arrow to download but when i replug the watch back into its charger with cable the device does nothing and the pc does nothing. the watch continues to charge as normal.
Hi . Personally i wouldnt update yet to V1.4 if you are on V1.2 and it working fine . Not until a few issues are worked out . If you do update this is available OTA so no need to flash . Dont forget to factory reset after install
turns out my issue was using the docking cable/charger the rollmes08 came with. switching to a different cable all together allowed my pc to see it. thank you!
LEM 14, although a had a few Lemfo’s, this version is again a cheap knock off of the Rollme, camera’s lower grade, not really waterproff for so far I know(specs telling differnt story). But all my previous Lemfo’s gave up due to sweat, playing tennis with my watch on. The Rollme after 4-5 months, still perfect.
Well lem14 with A10 has some serious issues for me that make me keep it in box and not using it right now…
One is that cannot use Google synchronise for contacts , calendar does not work, Google translation cannot work, viper cannot work, and many more Google apps that I use all time cannot work at all or synchronise to be useful…
Most important ofc for the use as a watch phone… is contacts to be able to know who is calling you and who to call… and ofc to be able to synchronise it with google server that now in Lem14 is impossible…
I was thinking if downgrade at A7 would solve this problem…
by the other hand is tested waterproof in swimming at sea… and good washing afterwards with fresh water and the sealing at the back was reinforced with silica gel
So my question is… does A7 versions synchronise Googke Contacts and Google Calendar??? These are the most important apps for me in any phone , watch or not, and in Lem14 are both not working…
