Ok, can you give me a sample of a face I can use for testing?
Because nothing was changed between the two versions.
So I need to show the firmware guys to demonstrate the problem.
This watchfaces I made by myself.
Thanks very much.
I will test
I have also passed the face to the firmware team
Thank you for your time
Yes it work fin on 1.2 but not on 1.4
I think we have version 1.4 and 1.3
Nope 1.2 and 1.4…
I will double check
The issue is 1.4 apparently
It should because it’s work when I rollback to 1.2
Apologies i missed that
Hey @Dr_Andy_Vishnu
If you get a chance - can you test as well please?
No worries
Will do but wont be near a pc until tonight mate
No rush mate.
I’m caught up with something else
Confirmed . Moving animations ( .gif files ) no longer working on latest firmware . Also lagging has appeared which i didnt have .
You mean arraytype 62 no more working.
Yes . No longer working
Received an over the air FW update last night. Worked fine, no issues. It’s 1.4.20200813. New charging screen & another user says some watch faces were added. I have 2 faces with complications and they each still work. There’s probably some under the hood changes, but there’s no change log to be found. That would be helpful. BTW: Scrolling seems to be the same as before.
Hi . Its the animated watch faces that are a problem with the latest firmware ( not touch complications ). Interesting that you have no lag at all when scrolling through the menu . Thanks for the update
