Its work only charge cable is on and just showing logo and battry animation than its gets turn off mode I tired to setup new firmware but I thınk ı cant make it
Try running battery down until watch doesnt turn on anymore. Then flash watch
its not working its only work while cable is on and just show battary loading and turn off.
I leave for charge abaout 1 night and its say %100 battary and still turn of I cant use it
But surely when you connect the cable to watch during flash process it starts ?
Can i ask do you know how to flash a watch ?
getting off when the animation is end. I tried to flash but I cant make it the progrees doesnt start I cant connect with pc( I cant see ın the pc files) I am asking how can I flash or how can ı open thıs watch
Have you installed the correct drivers ?
If you have flashed the correct firmware, it will be a hardware defect.
I found it from here S08 Firmware thread and I dowland this
S08_C7S_Rollme_V1.4_20200813.zip
Did you check the firmware version you had before you flashed?
I guess not if you never powered it on.
Which button did you try to power on ?
Did you press the lower button or the top button?
It is one of the few that don’t use the top button to control power if I remember right.
There are also versions of this for sale which are really LEM14 Android 10 so I hope that is not true for you.
Was it an S08 Pro or S08 ?
Did you buy it from here ?
https://www.aliexpress.us/item/3256804274435809.html?spm=a2g0o.order_list.order_list_main.36.2dfb1802mCtosg&gatewayAdapt=glo2usa
