Hello,
Does reflashing the stock rom (x5+) work better (battery life) instead of just resetting it?
Hello,
Dec 29, 2016 19:25:08 GMT 1 aapke said:
Hello,Does reflashing the stock rom (x5+) work better (battery life) instead of just resetting it?
Ok thanks will wait for your report
Ok thanks but my screen is just black after doing nothing powerswitch doesnt do anything and battery was almost full
Thanks anyway for your post, can you say how much it improves ??
Dec 31, 2016 22:53:03 GMT 1 aapke said:
Ok thanks but my screen is just black after doing nothing powerswitch doesnt do anything and battery was almost fullThanks anyway for your post, can you say how much it improves ??
It didnt improve its just the same as before so i uograded again.
ooh i didnt reset does it make such huge difference?
Ok will try that
Where do i get the rom for the X5+
Thanx
Jan 13, 2017 9:25:12 GMT 1 zabadok said:
Hi, Where do i get the rom for the X5+ Thanx
Thanx
/board/16/factory-firmware-downloads
Help needed!
I have Finow X5+.
I downloaded firmware from post -> X5 Plus (w616) Firmware, all necessary things like drivers and SPTool.
I did everything like it was in the instruction and at the end the SPTool said that process was succesful but… the watch cant turn ON. Its bricked. I can`t even see anything when connected to charger.
Please guys help me…
Thanks!
Jan 19, 2017 8:56:42 GMT 1 emmail said:
Help needed! I have Finow X5+. I downloaded firmware from post -> X5 Plus (w616) Firmware, all necessary things like drivers and SPTool. I did everything like it was in the instruction and at the end the SPTool said that process was succesful but... the watch can`t turn ON. It`s bricked. I can`t even see anything when connected to charger. Please guys help me... Thanks!
Help needed!
I have Finow X5+.
I downloaded firmware from post → X5 Plus (w616) Firmware, all necessary things like drivers and SPTool.
Thanks!
make sure the battery is more than 80% and try again, delete the rom from your computer and download it again.
Now I get this error
Help needed! I have Finow X5+. I downloaded firmware from post -> X5 Plus (w616) Firmware, all necessary things like drivers and SPTool. I did everything like it was in the instruction and at the end the SPTool said that process was succesful but... the watch can`t turn ON. It`s bricked. I can`t even see anything when connected to charger. Please guys help me... Thanks!With it off, try to get into recovery. Holding the power button + low button. When the finow logo appears, release the power button and continue to the low button. Go to clear EMMC and go to the power button. This will erase all of your smartwatch personal information.
Jan 19, 2017 11:54:17 GMT 1 edugasper said:Jan 19, 2017 8:56:42 GMT 1 emmail said:
