Questions about H18
You can debloat as you call it the H18 etc
You need this app
Tutorial
And a different cable ( 4 pin version ). I used the one from one of my ultra watches
A factory reset , update of maps the use this app
Mine took 30 mins outside before gps locked ( green )
thanx doc…i’ll have a look for a 4pin charger and will give it a try…
I just found this on AliExpress:
£2.23 | 2 Pin 4 Pin Smartwatch Charging Cable For DW89 DW88 DW98 S12 S9 Ultra 2 CDS9 DS8 CD99 H18 WK89 VP600 WTK89 GS29 Smart Watch
thanx for the link…ordered one today…
Thanks, I tried the suggestion method, factory reset, updated Google Maps, used the GPS test apps and waited a bit more than 30 minutes, no green GPS locked.
Next option I am trying is, to use GPS tether app from Play Store and tether my smartphone GPS to the H19. But it requires the H19 to enable GPS mock. But I cannot access the developer option to enable it. I think I have read somewhere here how to enable the developer option.
Strange as you have no green gps lock. Mine works fine with and without sim and no wifi ? To be honest its very fast. Tethering a waste of time as it doesnt sort your issue
Any other ideas can I try? Really need to use navigation on the smartwatch.
Is the GPS tether won’t do any good? I wanted to try out, but stuck at the developer option enabling.
Is the problem the same when you are in one of the square modes?
You can try Gboard. it allows you to adjust the kybd size as well as do voice typing.
For me if the GPS isnt working i’d send it back
hi doc, can you provide me with the smartwatch-developer-helper apk as it is no longer available in your google drive…thanx
Link fixed
thanx for the quick respons (as always)…
I ordered this watch 32+256GB Android 9.0 Smartwatch 4G LTE 1100Mah Battery Play Store Heart Rate 1.95 inch Spherical screen Smart Watch Men GPS WIFI and it says in the Settings About that it’s a H18 model. However I cannot enable the Developer Mode. Does anyone have any tips?
See topic Andorid 9 round screen watches with 16GB or even 32GB RAM?
It has beautiful screen and if it really has 32GB RAM (but even 16GB) it’‘d be great for my local LLM experimentation. But I need to get into developer mode.
Replied to your other post
com_google_android_syncadapters_contacts_9_6794505_28_minAPI23nodpi.apk (1.6 MB)
Havent tried this but its meant to fix the google sync issue on some A8 watches ?
Thanks but i have returned this watch to the seller..
FYI about the H18,
It has same C29 board - it’s just another branded version of the S13.
I think it is Domino, but not sure. It may run a different Android version, but I thought it was A13 :thinking:
