Hi Kadeshar,
Thanks for chipping in
I was under the impression that the watch will do like a phone, thus while in WiFi coverage switch off mobile data. Since I use a limited subscription of 1GB/month for the watch, and I live in an area with very limited mobile signal indoors, I would like my main connectivity at home to be via WiFi. I guess I could switch off mobile data then, but then I would have to remember to switch it on when leaving home - guess that will fail very often. And actually very comforting to see that WiFi took only 1% of the power, so Bluetooth is a much more obvious place to look.
I was using WiiWatch2, and the stats above must be including usage with this. Yesterday I switched to Watch Droid, and I do see how it is way superior to WiiWatch, but it was a good process to see WiiWatch2 first, to know good the difference between them.
Looks like stats after this nights charge, with watch off, is better, around 8% pr hour, so at least there is a chance of 10 hours or more usage today, and hope for more with some tuning tips from the community.
I repeatedly see the Google Sync tip, and I think I need to try that, only not sure what exactly to switch off, and how to sync manually when needed. I installed the settings search yesterday, so I am prepared now, when I get instructions. I was looking around in there yesterday and saw some ‘last sync times’ for different apps, and they were hours back, so sync doesn’t seem to be aggressively updating by the minute or hour. I haven’t installed Google mail, only Calendar synced. But it looked like I had location Sharing enabled, which I have on my phone, so probably a result of Google syncing my account settings. Wonder if I switch that off, if it will go off on both devices or only the watch - only one way to find out I guess …
Regarding the gesture controlled screen on, I wouldn’t mind switching that off and need to use the button, only I read in the forum of people limiting their button use, because of problems with buttons on previous models.
My watch would have turned off, if i had 4G.
