Tried something a bit different. Went for a steampunkish type face. Power at top seconds at bottom.
Feedback would be great.
Feel free to use but please don’t share.
Looks cool! Thank you for sharing.
Very nice . Love it
. If you are carefull you can sometimes get three .gif files to work max
You’re on a roll, Ryan… Be sure to submit it for the contest
Good to know how far you can push things.
Only unpublished watch faces can be submitted for the competition.
I need to think of some new ideas then. If I reconfigure a face I’d already made would that be acceptable? Just trying to get my head around the parameters.
It must be clearly different. However, using individual elements is not a problem.
Cool thank you
Steampunk is cool. I tried this on my Kospet Prime but I don’t see the animation in the bubble or the expanding red dot above it. Does this require UL ?
Hi yes I think it does, sorry should have put in the tags. I’ll remedy that. @droidtrix
And no Universal Launcher faces, if I’m correct.
@Edward Can I ask is it possible to use GIFs/animated watchfaces with the stock launcher? Or does that immediately require a different launcher?
Not that I know of, or I’d be using it
I’m pretty sure there’s an array type for gifs, but I don’t remember which number it was
Hi . Load this to your watch ( no other launcher required )
Look inside the clockskin .xml file to see
All possible with WFD
Apps need to be installed for touch icons to work
Array 100 for touch icons
It is Arraytype 62.
Thanks will have look later
I don’t use Universal Launcher myself…but that really is one seriously good looking watch face Ryan!
You come up with another 10 like this for the competition and you’ll win all the watches yourself!
Cheers, Doons
