Hey Guys,
I need your expertise.
I found out that you can use arraytype 62 for GIFs,
but it only works when you put a second arraytype 62 directly under it in the code.
The last one will not be shown, but it stops the first one from flickering.
If you don’t have it, the GIF is shown, but interrupted by a black screen.
Here is a face to check this out with…
By the way… I also found out, thart <mulrotate>-x</mulrotate> makes hands go counterclockwise, not slower than 1 in WFD.
