I need stock rom for Bakeey A4…
My smartwatch doesn’t work:((
Please, help me…
I am waiting for your help, thanks…
Sorry, but it’s not a fullandroid smartwatch. We can’t help you.
Where can I get help?
Try to contact the seller.
sorry but this is impossible
We don’t have the firmware for these watch, sorry.
Thank you for everything…
so can we find a suitable rom for my watch?
it is actually, it’s with 7.1.1
Ok, that changes everything. @Ferdi_kılıç: I’ll have a look. Sorry for my hasty judgment. I’ll see what I can do
@Ferdi_kılıç , here you go:
I’d advise you factory reset after flashing it, just to be sure
Thank you very much. I was still searching for this firmware.
I didn’t knew this watch…
Thank you, I will try this rom. I will tell you the result
thank you for your attention
Oh, you have to thank @noidremained . He prevented me from sending you into the desert and he also solved your problem. I apologize again for my misjudgment.
It doesn’t matter, the rom I installed earlier prevents my watch from shutting down :)) I’m waiting for my watch to run out of charge, I’ll try the rom you sent when it shuts down, I hope it works.
Yes, you are right. Let the battery run dry. Use firmware upgrade instead of download only in the flashtool.
Format All + Download or Firmware Upgrade
Which?
Firmware Update.
Ok, thanks…
