It gave scatter.txt error! Can we fix this problem?
hello my friend, unfortunately I couldn’t open the rom you sent yesterday!
how did you unzip the file that @noidremained has sended to you? I recommend 7zip.
The scatter.txt file I uploaded to the scatter-loading file section gave an error!
With Sp Flash Tool
Have you unpacked the zip file with 7zip? Or did you use an other tool?
I opened it with rar program.
Could you download 7zip and unpack it again? Then open the flashtool, navigate to the scatterfile and choose it.
I can open it with 7Zip program if you wish.
Ok, I’m at work now. I’ll try it when I get home and let you know the result. Thank you.
Hello my friend :)) Could you send me the rom I was looking for, all my problems were solved :)) Thank you again…
So you’ve solved the problem?
Thanks to you my friend, I solved the problem :)) Thank you…
Yesssss:)) Thank you very much…
