The Altiplano Ultimate Concept. This watch was presented for the first time in 2018, measures only 2 millimeters in height and went into series production two years ago. Piaget has now honored this watch with a one-off piece that pays tribute to the history of the Altiplano Ultimate Concept in some respects. It was presented at the “watches and wonders” watch fair this year.
Almost every gear moves, at roughly the speed determined by the arrangement of the gears and the number of teeth.
If you look closely, you will find a kind of battery indicator: The spring shows the charge status of the battery: if it is relaxed, the watch must be charged. If you do so and swiped the standard charge indicator aside, you can watch the spring rewind.
For the nightfiew download the “.watch” version.
credits: -www.piaget.com
download: -PiagetAltiplanoTribute400.zip - Google Drive
Download “.watch” version (with nightmode)
-piagetaltiplanonight.watch - Google Drive
Stunning . Have you resigned from your job
I am thinking about it. It was a kind of recycling. I have done this face two years ago:
-Piaget Altiplano ultimate Concept
I found the new watch today during my break. I just had to modify some pictures.
Perfectly! Beautiful work!
Many Thanks. In fact, I already did most of the work 2 years ago. together it was more than 60 hours of work. Maybe I can also do an SL version, I’ll take a look at it again.
You put in a lot of work, it has a tailor-made result
. Exceptional! Do you have any other hidden jewelry? The idea of power using a spring is super cool. Congratulations, added to the collection and to one of the watches.
Thank you @vladimir_lutzu . In fact, I’m not hiding anything, I post all the finished work here. Ok, some difficult projects are still waiting for problem solving before I can publish it. In fact, I already posted this idea with the spring as a battery indicator 2 years ago.
Ok, I have made some tests. I’m quite sure that I will be able to create a full functional stocklauncher version of this face. For stocklauncher 7.1 and higher.
I’ve already done the most of the work. I’ll need some more time…
felt like nobody noticed this:
-Martian Notifier Smartwatch
You might have a look at it. It is a running text that changes.
Ok, I have spend some hours to realize that I’m not able to make it fully work on stocklaucher. I’m sorry.
