I wanted to give fw3.0 another chance.
flashed it, everything went great.
I wanted to do a factory reset, the screen said “erasing”, went black, and it remained black every since.
nothing seems to help, flashing various FWs goes as it should, everything looks ok, but the watch cant be turned on after the procedure.
when off and connected to the PC it only sometimes (once in every 10 attempts or so) flashes the kospet logo, the battery icon shows for a sec or 2 and the screen goes black again. other times nothing happens except the “usb connected” sound goes of, quickly followed by "usb disconnected sound.
yeah, I thought that too.
but it seems like the watch starts a perpetual loop of some kind switching on and off continuously as soon the battery gets charged even a slightest bit.: thus connected and disconnected sounds when i connect the watch to the PC via USB, I think.
it also gets a bit warm, which makes me think it is doing something, even the screen is all black. then it just cool off when the battery is discharged.
I flashed the watch a fair number of times using the very same procedure, and it always worked just fine.
I wonder what could get screwed up this time.
kind of sad cuz I really liked the optimus pro, it was just a step away from being a perfect watch IMHO.
anyways, it seems like I’m getting a new watch, which is pretty cool
At this point any attempt you take to charge the watch will fail due to incorrect or unsuccessful flash, however the watch is discharging. Leave it over night to fully discharge.
In the morning, make sure to flash the confirmed official factory firmware for the Optimus Pro using firmware upgrade. Once the flash is complete leave the watch on the charger. Eventually the watch will turn on and show the charging animation. If the flash fails due to some reason, remove the watch from the dock for 10 mins to fully discharge before trying again.
Mine does too today. Kospet prime. Around 40% battery and after 1 unsucessful call it just went black. Charging only show low battery but not charging. Extremely hot too. Exactly 2 month after I bought it sigh.
Flashing didn’t fix it. Charge it for an hour after flashing but it only shows red battery image. If what you say is true, do I need to replace the battery?. With corona doing its world tour I doubt it will ship.
To be honest we do not have a solution for this . If flashing doesnt work and i also dont know if a new battery will help ( maybe unless if new battery is fully charged ? when you insert it )
