At home with wifi connected will make the heart rate sensor perform normally. Outside it’s broken.
That’s absolutely crazy…
Sadly something that firmware is not going to to fix because it is a hardware fault I think…
But I guess you know that already after reading the comments here…
Yeah. Strange though the monitor actually working fine for 40 mins inside the house and WiFi. Lol
I’m going to open mine up and have a look.
Curious indeed…
I’m actually wondering if heat is making a difference…
WiFi brings heat and heat causes expansion etc…
You see what I’m getting at?
It may be that expanding inside is making a connection work that doesn’t work when it’s cool.
It sounds crazy but I can’t think of anything else that can make sense…
So I will have to investigate
If it wasnt you we probably wouldnt believe it lol
can you help me
I dont fine drive lem 10
how install ROM in lem 10
Lol! Hehe that’s a funny way of putting it
I will try when The heat is back (i.e summer) see what happens then.
(post withdrawn by author, will be automatically deleted in 24 hours unless flagged)
do you need twrp?
If you only need root you can follow the instructions posted later in the same 4pda thread:
http://4pda.ru/forum/index.php?showtopic=966040&st=100#entry89857874
google translate translation:
https://translate.google.com/translate?sl=ru&tl=en&u=http%3A%2F%2F4pda.ru%2Fforum%2Findex.php%3Fshowtopic%3D966040%26st%3D100%23entry89857874
does that mean you got it working, or did you read it somewhere?
Looks like you are right, I’ll ask a russian girl friend(wish i could skip the space) of mine to help me with registering there tomorrow and I’ll see if I can download it
I tried too much and did not succeed
@atta04444 @noidremained as this thread I created is about this particular firmware, I’d like it if you didn’t hijack it to talk about other things. please remove your posts. I have flagged them for moderation.
Is there a good reason to use this firmware thread to talk about twrp instead of creating a new topic??
you’re right, it would have fitted better in another thread, for example the following one: Why cannot modified the LEM10's system.img?
If the mods wish to they can move it there
Almost every single one of my threads gets hijacked. Not sure why people don’t apply net etiquette,
