Doesn’t make any difference when using SP Flash Tools. Everything will be replaced by the firmware.
This is one the few occasions when you you upgrade firmware option. It’s a fresh start.
Mar 5, 2017 14:16:26 GMT 1 daniel said:Mar 2, 2017 20:24:38 GMT 1 gdisckaraoke said:
I have to say a massive, massive thanks to Ricktop for a wonderful launcher program which has .watch support! fantastic job buddy and you deserve all the plaudits coming your way. Also a big thanks to Pablo11 for sorting out the screen resolution for the Lemfo/DM368/Y3 firmware updates. Thanks again for all your hard work.
Hi Gdisc,I like to have the update to fixed the resolution issue… do you know where can I have it? Thanks!
wat resolution issue ?
Mar 9, 2017 23:46:02 GMT 1 gdisckaraoke said:
The new DM368 firmware for March 2017 still knocks out the watch faces when using Erics Launcher. It looks like the screen resolution issue is still there....Does anyone know if this is the same for the updated LEMFO firmware???
wat the screen resolution issue ?
My Domino DM368 watch has HEHUI v1.3 of 13 Feb 2017 and the latest FW posted for Domino is v1.2 but of 03 March 2017. Why the backtrack in ver numbers? Is it because of company’s numbering?
Is it possible to use the FitWare app to control Zeblaze Thor?
I must adm8t i flashed my Dm368 to the Iqi3 firmware and have never looked back.
I’m not sure if i should flash it to the iqi4 firmware or not, i don’t know what the differences are if any…
Sept 10, 2017 16:05:49 GMT 1 gdisckaraoke said:
I must adm8t i flashed my Dm368 to the Iqi3 firmware and have never looked back.I’m not sure if i should flash it to the iqi4 firmware or not, i don’t know what the differences are if any…
I also have dm368, i had I3 FW for quite some time then switched to I4 pro FW just because of viewing watchface on wrist turn.
Sept 10, 2017 16:15:43 GMT 1 firefoot007 said:Sept 10, 2017 16:05:49 GMT 1 gdisckaraoke said:
But dm368 and I4 pro have diferent RAM and Storage! Sure dm368 works well with I4 pro firmware?
Yes but u have to be sure to flash only the required files. Dont falsh preloader and lk.bin.
