My rollme s08 stopped working
After of more than one and a half year of very good functioning, suddenly my watch stopped working. It went blank and refused to start again. I tried recharging it again and reboot , but it seems that it was dead. What else can I do, if I can do something?
Even if the battery is empty, it should be possible to flash the firmware. It might help, as long it’s not a hardware problem.
You can find everything you need here:
-S08 Firmware thread
Use the “firmware update” option in the flashtool.
Thanks for the respond. I will try.
Here is a tutorial how to do it. It’s for another watch, but it will work for your watch, too:
Make sure that you are using the firmware I linked for you. Use “firmware update” in the flashtool instead of “download only”.
Thanks for the respond. I will try everything you suggest.
