I am new to this forum and have recently purchased a Lokmat APPLLP Pro 4. Is there a way to set the screen timeout when using 'lift to wake"? My screen turns off so quickly I can barely read the watchface. Double tap does not work neither. This is way different than setting for screen timeout to say 30 sec or so to read the screen info and it’s display.
No, that’s not possible.
A simple fix for this is to tap the screen when it appears and it will stay on until it times out normally.
Hello.
There is also same topics in this forum.
Some macro tools can resolve this problem, but they use battery a little.
Its my opinion that manufacturer must recognizes the time of “Lift to wake” is too short in A10 and A11 watch.
Thank you kindly, nice work around!
