Lemfo Les1 New Firmware?
Dec 12, 2017 18:32:42 GMT 1 soniasophie9697 said:
Dec 12, 2017 18:02:24 GMT 1 pycon said:
What about new firmware version 2017.11.22 ?
if the update is from the forum then this one include bt calls.
Great, where to download it ?!
/thread/1036/les-stock-firmware-calling-version
in sp f.tool you need to choose upgrade and not download only!
Can u explain to me how to flash it with more details, please ? I haven’t understood…
use this video but remember you need to choose upgrade and not downlod only.
Also with UPGRADE only option, all the content of the internal memory will be destroyed ?
at least when i upgraded my kw99 everything was wiped.
It’s IMPOSSIBLE to flash latest firmware with FIRMWARE UPGRADE option AND PRELOADER UNCHECKED !!!
If I choose Firmware Upgrade, SP Tools put the tick on the flag of Preloader, if I untick this flag, SP Tools returns on Download Only…
It’s impossible !
Dec 14, 2017 23:35:00 GMT 1 pycon said:
It's IMPOSSIBLE to flash latest firmware with FIRMWARE UPGRADE option AND PRELOADER UNCHECKED !!!
It’s impossible !
preloader should be checked:) it is the firmware for this watch so it needed.
It’s impossible !
Ahhhhhh… I always read to untick it otherwise the procedure could destroy the IMEI etc…
So i made the mistake with putting Download only option. Guys can i downgrade the firmware for Les1? What are the steps for it and can i after downgrade, upgrade watch with latest BT firmware and ofc with firmware upgrade option, preloader is checked then.
only if it is different firmware of another model that suits your watch:)
yes, you can, just download the last firmware for your watch which is'nt the upgraded one flash it and then you can upgrade the watch again.
yes, you can, just download the last firmware for your watch which is’nt the upgraded one flash it and then you can upgrade the watch again.
After downgrade i can put a new firmware with firmware update option and preloader checked am i right? Should i go with download or firmware update when i am going to downgrade my watch?
read carefully what pablo11 writes in the thread with the firmware.  all instructions are there.
Latest official FW for LES 1 is now Z10-YFZ-V11-20180206. Received that FW OTA. Kernel is 3.10.72 Feb 06 2018. Android security patch level is 2016-06-01.
Regards,
DrGo
Regards,
DrGo
Where to manually download it ? Any BT disconnection problem?
Regards,
DrGo
Checked update.zip, it is 12.5 Mb totally, can't find and check changelog though
Regards,
DrGo
12.5 MB ?
So it’s not a new firmware, just a new android patch o a new updated kernel to flash over previous system
So no needs to install it, better to wait a real new firmware version.
Just to try, I’ve looked for new wifi updates… Ok, found it. The watch dowdload it in a while and flashed at next reboot (through TWRP). Watch reboots and updates all the apps. Well, no differences even if Settings / Info it says 2018.02.06… So, I noticed that TWRP recovery has been overwritter and in the Internal Memory there’s no ZIP or other file related to this update, so no way to keep it.
Feb 18, 2018 12:52:59 GMT 1 pycon said:
Just to try, I've looked for new wifi updates... Ok, found it. The watch dowdload it in a while and flashed at next reboot (through TWRP). Watch reboots and updates all the apps. Well, no differences even if Settings / Info it says 2018.02.06... So, I noticed that TWRP recovery has been overwritter and in the Internal Memory there's no ZIP or other file related to this update, so no way to keep it.
After updating, the watch has restarted to disconnect BT randomly every 1 / 2 minutes
Tested with :
  • Watch Droid Phone => BT disconnection
  • WiiWear => BT disconnection
  • WiiWatch => impossible to connect, as in previous firmware
Tomorrow I’ll go back to July 2017 firmware
EDIT : this evening @ 10 PM … maybe … I’ve found a solution without needing to revert back to old firmware versions !!!
