Lemfo Les1 New Firmware?
Feb 21, 2018 16:48:50 GMT 1 pycon said:
Feb 18, 2018 12:52:59 GMT 1 pycon said:
Just to try, I've looked for new wifi updates... Ok, found it. The watch dowdload it in a while and flashed at next reboot (through TWRP). Watch reboots and updates all the apps. Well, no differences even if Settings / Info it says 2018.02.06... So, I noticed that TWRP recovery has been overwritter and in the Internal Memory there's no ZIP or other file related to this update, so no way to keep it.
After updating, the watch has restarted to disconnect BT randomly every 1 / 2 minutes
Tested with :
  • Watch Droid Phone => BT disconnection
  • WiiWear => BT disconnection
  • WiiWatch => impossible to connect, as in previous firmware
Tomorrow I’ll go back to July 2017 firmware
EDIT : this evening @ 10 PM … maybe … I’ve found a solution without needing to revert back to old firmware versions !!!
Nice one cannot wait to try a new solution
I need some time to test some rules and this weekend, if all's working, I'll be happy to tell u
We are patiently waiting
No I've just tried in the lunch time, during a boring working day.
First attempts to manage BT power settings on the watch seems to not solve disconnections
Try again with other apps in the weekend…
Tested with :
The Blutooth disconnects with Watch Droid Phone is fixable…turn your wifi on when you have your blutooth on then connect…you dont need to connect to a wifi network, just have it running in the background. From then on it wont disconnect from Watch Droid Phone.
Strange but ok, I'll try !
Hi, Does Someone manag to call bluettoh with the new version of February 6th through custom update? Thanks
No, no way. Only official firware receive OTA like 2018.02.06 Patch and 2018.11.22 BT is not official
Watch Droid got update on phone app and assistant. It works so much better than before, i tried it and i got no single disconnect. I was on bluetooth on watch all the time, wifi was off.
can anyone upload the lastest firmware possible please
Go back to the Home page and look at the top of this Board, it is the first post.
