Nov 22, 2017 4:05:48 GMT 1kaptk said: I reseted the watch three times and re install the update two, but the connection problems continue. Can i do a downgrade to return to the previous firmware?
I think u can just use SP Tools to flash firmware 13.07.17 again
You can downgrade to the previous version. I think it could be more the apps on the phone are misbehaving as when I reinstall the app and allow “Keep App On in Background” privileges again everything seems to work.
I did downgrade but am now on the latest firmware again and using the WiiWatch app with the hack described in the forum. Everything is running fine at the moment and i did a reboot on both devices where they connected fine again and stable.
Nov 22, 2017 17:56:27 GMT 1kaptk said: You can downgrade to the previous version. I think it could be more the apps on the phone are misbehaving as when I reinstall the app and allow "Keep App On in Background" privileges again everything seems to work.
I suggest to u to use APP OP X from Play Store in order to set all the possible authorizations of every app. Rooted device only, it works great
My connection problems continue… I try factory reset, reinstall firmware, unpair the wacth and phone, install wacth droid,wiiwear,m2d, but nothing worked… The only that i didnt try is downgrade… Any suggestion?
Nov 18, 2017 17:17:52 GMT 1pablo11 said: If you ever use the firmware upgrade option you will notice that it performs an extra step by formatting the system, data and cache and the pre-loader - in fact all the partitions you are going to be flashing. But you will not lose your security info partition where IMEI and MAC addresses are stored.
Using download only mode does not format all these partitions and so you can often end up with ghost files from previous installs.
If you use format all + download option you lose all IMEI and absolutely everything. Never use this option!!
if i use the firmware upgrade option i leave the preloader ticked ?
just want to make sure
i did this i lost everything imei i understand how i solve it? I do not have cellular network
Nov 24, 2017 14:31:37 GMT 1rockamezzanotte said: thank you would you tell me how to make the root? if you can link to the program to use ... I'm not very experienced thanks
thank you, but unfortunately I did not succeed … is there a simpler way? or do I have rights to any of you can connect to my pc and root it to my les 1?
thank you, but unfortunately I did not succeed ... is there a simpler way? or do I have rights to any of you can connect to my pc and root it to my les 1?
root is great but not always needed, if it is about battery or delete system files or custom roms (not many of them) then yes you need root, but do'nt root the watch for other reasons.
