Hello all I’m trying the software…so when the phone is in charge I receive every seconds a vibration on the watch…how I can disable this function? So about watch droid I can’t associate my device with the software…pls help me thanks and regards
May 20, 2018 16:23:50 GMT 1 markop1985 said:
Hello all I'm trying the software..so when the phone is in charge I receive every seconds a vibration on the watch...how I can disable this function? So about watch droid I can't associate my device with the software..pls help me thanks and regards
vibrations of notifications? if so,just turn off notifications when it charges or put it on silent mode.
 Did you download and install both softwares as stated above?  And did you sync your phones Bluetooth to the watches Bluetooth?  If so, is Bluetooth turned on?
Dead all Ok I found the device in the list of devices…now it works bit there is also a big problem because when you write a message with keyboard or with your voice there isn’t the button for send the message and you can’t send the message…another thing can we choose another keyboard more simple and easy to use ?
For who have used this watch…the battery will sure how much hours?
Thanks and regards
Hi All . Just recieved Lemfo Lem 7 . Have tried everything and cannot get screen to come on when raised ? Tried everything and reset watch ? Turned on in all settings ?
I’m baffled ?
Any help appreciated
Also a few other pointers when paired with a iphone 6 . Connection rarely works and doesnt re-connect with app ? Also the raise to turn on screen and silent mode doesnt work / sync at all ? Lookup device does work .
Not a great start for me
May 21, 2018 4:39:36 GMT 1 markop1985 said:
Dead all Ok I found the device in the list of devices..now it works bit there is also a big problem because when you write a message with keyboard or with your voice there isn't the button for send the message and you can't send the message..another thing can we choose another keyboard more simple and easy to use ? For who have used this watch..the battery will sure how much hours? Thanks and regards
I emailed the developer about the text msgs, so waiting on a reply. You can download another keyboard such as google keyboard to your watch.
If you are talking about Watch Droid I use the voice function to send a reply and once your message is completed there is an icon in the upper right corner that I use to send the message. It works really well.
Still dont know where come from the sound of this watch phone… Possible to have a closer look about the loudspeaker ?
May 22, 2018 8:56:59 GMT 1 kiki301 said:
Still dont know where come from the sound of this watch phone... Possible to have a closer look about the loudspeaker ?
In a previous post on this board I confirmed that the speaker port is located on the back of the watch at the bottom. This was verified by Mr. Ticks on his You Tube channel.
Thanks for your answer, but what i see on the back of the watch at the bottom it’s the sim card door not the speaker port …
You can’t see it from this view - directly above the back cover.
Further down, between the sim and the strap is a little slot and this is where the speaker is.
Hope this helps?
I noticed that the sound did not come from the side as I initially thought/experienced... Great to have confirmation!
After a few days, I have a clearer idea of the watch possibilities.
It last a day and a half with my settings. 3G with data (4G kills the battery in no time). Location activated. WiFi activated. Screen on raising activated. I don’t use it as a notification device (with Bluetooth) as most people do.
Bluetooth is not as good with the battery as I thought (maybe it’s because it’always on?) so I have to do more investigation on it.
I’m mainly using the watch as a time accessory and cell phone backup, with fitness (heart rate) as an after though.
Fitness is not as good as I wanted it to be. It’s a big downside as I wanted to track my activities… I’ve tried a few apps but none seems to be accessing data from the heart sensor… Any suggestions?
Ok, but have a doubt about sound volume particullary in phone call whit a so small hole and on the skin …
krapulant
try this cos it syncs with google fit.
play.google.com/store/apps/details?id=inc.makerbob.sbobka.heartontop
this one also uses the heartrate sensor of the watch: play.google.com/store/apps/details?id=com.tincore.and.gliderun
May 22, 2018 18:09:44 GMT 1 kiki301 said:
Ok, but have a doubt about sound volume particullary in phone call whit a so small hole and on the skin ...
Not sure what you are referring to. The speaker, as we pointed out is in the back of the watch at the bottom of the case and is larger than the average speaker port.
Is this a revision of the device? The back of mine is different (text and screws).
Hi everyone, thanks for you’re comments, I brought the lem7 after read the whole thread.
I’ve found a issue with bluetooth range using bt speakers: my main problem is that the audio drops with airpods, even when the lem7 is on the wrist resting on the table (30~40cm)
I tried with a Xiaomi Mi Bluetooth with the same result: about >30cm (~12") the audio begins to drop.
Maybe a prototype? Curious about the misspelling of the word Smart.
Lol
