Pablo, do you have a bug fix log or an update log? I mean, what is corrected in 2.5 vs 2.4, would be interesting to know if you log all the changes that are made to the firmwares version!
Thanx
Thanx
I have a suggestion for the next LEM7 firmware update. Having the watch to āshut upā on boot. The sound it makes when it boots for me doesnāt make sense. When my watch is dead and I put it on the charger arriving late at 2am, the watch boots when put on the craddle and then you hear the āsongā that wakes up my girlfriend. I liked the Zeblaze firmware for that (silent on boot)
Is anyone getting this Serial # when trying: adb devices
List of devices attached
0123456789ABCDEF
device
I forgot to check before updating with SP Flash Tool, and I just want to confirm the secro.bin didnāt have anything to do with this.
/proc/cmdlineĀ shows: androidboot.serialno=0123456789ABCDEF as well
Jul 26, 2018 22:47:37 GMT 1 unforsaken said:
Is anyone getting this Serial # when trying: adb devicesList of devices attached
0123456789ABCDEFdevice
/proc/cmdline shows: androidboot.serialno=0123456789ABCDEF as well
Does the update fix the gps issue?
Guys,
Check if you have the option on bt if youĀ have bt calling it turns out that we doānt need an app for bt calling it is thereā¦iāve checked with Samsung phone and Huawei phone and it works.
soniasophie9697 you will need to be very specific about this.
Some pictures or a how to will need to be made - itās too broad a statement for people to just āunderstand what you meanā
Does anyone flashed the new firmware and the screen-problems went away? Otherwise it seems that the LEM7-Screen had in general a problem with durabilityā¦
Several People have problems with the screen after 2-3 months⦠like i do (http:///thread/2540/screen-moving-touch-recognized-bottom)ā¦
Therefore the question, will the firmwareupdate solve the issue or is it a hardware related thing?
The gps issue is hardware not software .
Gps-problem mabe based on a very short antennaā¦
why they removed the theme of the firmware update? where we will now take new versions ??
Aug 4, 2018 18:37:06 GMT 1 chris4you said:
Gps-problem mabe based on a very short antenna...
Jul 26, 2018 2:28:49 GMT 1 coolsly said:
I have a suggestion for the next LEM7 firmware update. Having the watch to "shut up" on boot. The sound it makes when it boots for me doesn't make sense. When my watch is dead and I put it on the charger arriving late at 2am, the watch boots when put on the craddle and then you hear the "song" that wakes up my girlfriend. I liked the Zeblaze firmware for that (silent on boot)
little battery for android 7, you need more. otherwise, the design could be better, less thick, belt change, but despite everything works very well.
My notifications recently stopped waking up the screen (it would just vibrate). This was most likely caused after I re-loaded the firmware. I tried downgrading the firmware, but the issue was still present. I have found the setting that turns this back on for those that experience this issue. I did try the app that Pablo suggested (Heads Up Notifications), but I couldnāt get it configured to work the way I needed it. I also searched but couldnāt find the answer here.
To turn on āwake screenā in the event it gets disabled (in my case) follow the path:
I needed to turn on āConnect Phoneā and āWatchClockSkinā (Iām using universal launcher). āWatchā was already turn on in my case.
Hope this helps someone
Hi guys, Iāve experienced a major issue with this watch 10 days after I purchased it.
The sim card is no longer recognized (no water, no dust, no heat, ā¦). It worked fine during 10 days. The sim card still works on my previous phone.
Iām about to flash the lem7 with the latest firmware but if you have a better idea, I will be glad to concider it. I really donāt know what good flashing the watch will do to this issue but thatās the only thing I see me doing at this stage. Any advise, please tell me.
Ultimately, I would like the manufacturer to replace it if I canāt fix it with this upgrage but I donāt know to whom to speakā¦
Hi guys, I've experienced a major issue with this watch 10 days after I purchased it.The sim card is no longer recognized (no water, no dust, no heat, ā¦). It worked fine during 10 days. The sim card still works on my previous phone.
Iām about to flash the lem7 with the latest firmware but if you have a better idea, I will be glad to concider it. I really donāt know what good flashing the watch will do to this issue but thatās the only thing I see me doing at this stage. Any advise, please tell me.Ultimately, I would like the manufacturer to replace it if I canāt fix it with this upgrage but I donāt know to whom to speakā¦
Thanks for your answers Sonia and Pablo.
I really donāt know what happened but this morning after playing with the airplane mode desperately, the watch found the sim card again.
That can seem strange but I can tell you that Iāve spent hours in the settings to try to sort out this issue.
I will keep you updated if I meet this issue again. Good day.
