We are getting reports of bad gps performance with the LEM7. But not with the Thor 4.
As both are the same it is pointing to the strap antenna for the LEM7.
I need to look into this further.
Jun 24, 2018 19:07:36 GMT 1 coolsly said:any down or + sides using the Thor4 fw? Is the Thor4 also on when charging? Thnx
The display of the Thor4 is not on during charging.
Jun 25, 2018 15:00:17 GMT 1 pablo11 said:
We are getting reports of bad gps performance with the LEM7. But not with the Thor 4. As both are the same it is pointing to the strap antenna for the LEM7.I need to look into this further.
Thankyou . I can also confirm that i havent put watch under any stress etc . Shame as GPS lock was super fast before ![]()
Jun 25, 2018 16:03:16 GMT 1 Tim And Pierce Collins said:Jun 25, 2018 15:00:17 GMT 1 pablo11 said:
why doānt you downgrade to the firmware before the update, i have done this.
Okay . Are you saying you had similar problems after update ?
Jun 25, 2018 18:30:29 GMT 1 soniasophie9697 said:
Jun 25, 2018 16:33:34 GMT 1 Tim And Pierce Collins said:
yep.
Thankyou . Was yours really good before update ?
Jun 25, 2018 15:46:49 GMT 1 mgk said:Jun 24, 2018 19:07:36 GMT 1 coolsly said:
Which one do you prefer... any down or + sides using the Thor4 fw? Is the Thor4 also on when charging? Thnx
Jun 25, 2018 20:09:01 GMT 1 coolsly said:Jun 25, 2018 15:46:49 GMT 1 mgk said:
I flashed it and it makes a HUGE difference in the watch temperature when charging so for now, Zeblaze FW it will be for me... We'll see the evolution of both firmware... ALSO, when you boot the watch and reboot it, there's no sound which is also a big + for me.
So what version are you using now Sophie? I will have to test it outā¦
Jun 26, 2018 1:53:09 GMT 1 pablo11 said:
So what version are you using now Sophie? I will have to test it out.....
I went back to the firmware that iāve flashed but didānt do the ota updates. haveānt checked yet outside the gps just indoors and it doesānt work.
Jun 26, 2018 2:59:23 GMT 1 coolsly said:Jun 26, 2018 1:52:03 GMT 1 pablo11 said:
Not quite sure I understand this... Are you saying that your screen stayed on all the time when you charged the watch previously and it got hot? This is not good at all. Watch should remain powered on when you are charging but screen should be off.
My LEM7 screen was on when charging. Also, when powering up the watch, it was making a "song" and when restarting, it was also doing a "song" (like all Lemfo watches) when booting and the Zeblaze firmware don't so it suits my needs better for now...!
So there was definitely a problem with the watch set up the way it was.
Did you take the OTA when you were using the LEM7 firmware?
If so did you factory reset?
I would be very interested to hear what it would be like if you flashed the full firmware package posted here for the LEM7. But understand that it is a pain having to flash againā¦
I would also be interested to hear what your gps is like using the Thor 4 firmware.
If you can test outside ( no sim ) iād appreciate it
Yep I did.
Here is the result from the engineering app.
But, I still need to talk to Sophie and find out what happened.
Iāve been caught up with work last couple of daysā¦
Jun 26, 2018 10:21:34 GMT 1 pablo11 said:
Yep I did.Here is the result from the engineering app.
Hi . Tried same engineering app and nothing ? Not a single blip . Really hope this this is the ota update issue and not hardware .
Just tried another full reset . Nothing . GPS dead
Jun 26, 2018 22:12:57 GMT 1 Tim And Pierce Collins said:Jun 26, 2018 10:21:34 GMT 1 pablo11 said:
Just tried another full reset . Nothing . GPS deadThanks
A way of training your gps is to go into settings/connect/gps and change to Device only. Leave for a while and use engineering mode and change GPS mode to Hot start. Turn on gpsĀ to monitor. It should come good off the wrist or outdoors at first. Then on wrist outdoors.
