Yep, I agree
Always easier to manage sim security options on a phone rather than the watch.
But it’s do-able… As Sonia says it is found with settings search or gesture search.
I prefer gesture search because you can get right down into the services and other stuff. Sadly it is now deprecated and has been removed from the play store.
Have to google for the apk now.
So you get a few errors on Android 7 due to lack of support, but generally it still works and remains my favourite
Pablo.
I found a way to connect to wiiwatch 2 and connect the phone to the clock. The theme of the clock was downloaded and the image appeared. Avra Kadabra.
Yes, this is the expected behaviour of the WiiWatch2 app.
By the way, we are an English language forum and so posts which are not in English get removed. Because no one understands them.
Pablo11.
pablo11 AvatarJun 4, 2018 8:40:30 GMT 1 pablo11 said:
If people are worried about the black screen issue - follow this information.
Enable USB debugging on your watches. Go to the watch settings and scroll to the very last option which should be “About Watch”
Go into this menu and open “Developer Options” and select USB Debugging.
It allows you to run adb reboot recovery from your PC if you get stuck like this.
it will reboot to the screen tat says “No Command” this is stock recovery.
If you press the main button for a few seconds it will go from this screen to the recovery options.
From here you can wipe cache and reboot. This will reset the watch.
To use adb tools Google minimal adb and fastboot and install it.
Sorry if this is a very stupid question but I’m still waiting for my LEM7 and I’ve never owned a smartwatch:
How do you connect the watch to your PC to use adb tools?
Search Google for using adb tools. Very easy to use.
Jun 5, 2018 23:10:46 GMT 1 taxidermista said:
same as any other android device:)
Hi all . I just wanted to share my joy !!!
As i am in love with my “ Lem 7 “ and now my wife has left me and gone i have decided to marry my true love “ Lemfy “ as i call her . She is a beautiful watch . She goes everywhere with me !!!
You are all invited to the wedding . Its at Hartlepool uniteds football ground 1pm on the 20th July ( UK ) . The buffet after is at the “ raglan social club “ next to the football ground . I will look forward to seeing you all
Thankyou
Ps - Cockneys welcome as long as you dont “ give it the big-un “ and upset the locals
Nutta!!! lol
Sorry, I’m asking about physical connection. How do you connect your watch to the PC? I don’t see any micro-usb or similar data connector on the watch.
Sorry, I’m asking about physical connection. How do you connect your watch to the PC? I don’t see any micro-usb or similar connector on the watch.
With charging cable that comes with the watch.
With the LEM7 you set your watch on the extended battery pack. The battery pack has a usb socket which you connect to the pc. Don’t forget to enable usb debugging as I said before.
With the LEM7 you cannot use a usb cable without the power bank. I am looking into this but at the moment it is a requirement to use the power bank as it connector.
Sorry, I'm asking about physical connection. How do you connect your watch to the PC? I don't see any micro-usb or similar data connector on the watch.
With the LEM7 you set your watch on the extended battery pack. The battery pack has a usb socket which you connect to the pc. Don't forget to enable usb debugging as I said before. With the LEM7 you cannot use a usb cable without the power bank. I am looking into this but at the moment it is a requirement to use the power bank as it connector.
Ok, thank you! Not in thousand years would I believe those four tiny copper contacts for charging could support a data connection too! :-O
Hi all! who ever managed to launch the program for the phone this watch Wiiwatch2…
Today I did a comparison between Google Fit and the Fit apps on the watch. There is a noticable difference.
The watch says 6735 steps with its own apps while Google Fit says 8213 steps over the same activities. I started with both phone and watch.
Both phone and watch have Google Fit.
Fit on the watch gives exact the same number as the phone, so I presume this is correct data. I presume the watch bases its data on movement, not on GPS?
Jun 6, 2018 13:53:45 GMT 1 biker73 said:
Hi all! who ever managed to launch the program for the phone this watch Wiiwatch2..
Sorry, what do you mean exactly? I have tested the WiiWatch2 app with this firmware and it works fine?
Jun 6, 2018 13:54:39 GMT 1 barnowl said:
Today I did a comparison between Google Fit and the Fit apps on the watch. There is a noticable difference. The watch says 6735 steps with its own apps while Google Fit says 8213 steps over the same activities. I started with both phone and watch. Both phone and watch have Google Fit.
You would be correct on movement. Mr. Ticks did a video on just the fitness application of the Lem 7.
Yes, I saw that video. The only thing I don’t understand is that the apps installed from the Play store support GPS but why is it not implemented in the native apps?
sorry, I’m talking about a companion program for the phone! The built-in program does not connect to the phone, how can I fix it? I about the program wiiwatch2,help!
what is the firmware version for your watch? and what program?
WiiWatch 2 program and the LEM7 firmware, v1.4, v1.6 and v1.8.
They all work fine with Android phones. Not so good on IOS but working.
As long as you pair the devices correctly it’s fine.
