May 29, 2018 18:57:40 GMT 1 ashishaggarwal007 said:
Hi Pablo,
I hope you and your wife are doing well. I was just exploring this forum and read about you being the caregiver. Wish her Strength!!
For watch - I am using it now for 4 days, and have few questions:
  1. What is the best way to get the screen on raising/tilting the wrist - it works very sporadically.
  2. What’s this ‘Hand on Bright’ mode?
  3. Is there a way to keep the watch display ‘Always on’?.. Without pressing the side red button. I would like to use it while keeping minimal brightness to save on battery - especially when mobile connectivity is of lesser importance (Airplane mode), than ‘looking at the watch to read time’
  4. Do you agree with the thoughts of other members here that if I set the watch network as 3G, then the battery consumption would be lower (than 4G)?
  5. I am not impatient about the Bluetooth calling, or firmware update currently - so, please take your time that you need it getting it right
Thanks,
Ashish
3g much better battery :+1:
Hi Pablo,
Thanks,
Ashish
3g much better battery 👍
I concur.
Has anyone tested the hidden “LTE band2” in USA AT&T or T-mobile?
If it works, then I want to buy ASAP…
If some one has LEM7 in USA, please report
May 30, 2018 1:05:48 GMT 1 nekojiru55 said:
Has anyone tested the hidden "LTE band2" in USA AT&T or T-mobile? If it works, then I want to buy ASAP... If some one has LEM7 in USA, please report
Where is located the "hidden LTE band2"
Just to be clear about this.... The B2 band is not hidden. It's there the same as the others. Also worth noting is the fact that the watch only uses 4G for data. Therefore, unless you want to stream a movie to your watch - you will get MUCH better battery life using 3G. Calls are made using 3G or 2G depending on your carrier. The watch will NOT use 4G for calls - full stop.
If you set preferred network to 3G in the settings for Cellular you will get a very good experience with the watch.
4G is excellent if you need to download something fast or watch a video over the internet.
Hope this helps.
Pablo
I just received my LEM7. This is my first smart watch.
Is it possible to run “Google Assistant” on the watch. I receive a message that “The Google Assistant isn’t available on this device” I even tried to side load the APK but get the message when I launch the app.
Thank you;
Massimo
Thank you;
Massimo
The short answer is no.
This watch is not recognised by Google and as such will not allow Assistant to be used.
To be clear again - it will be able to use many Google apps but as an unrecognised device - we cannot expect to use some of the more exclusive apps like assistant.
Thank you for the quick reply Pablo.
Thanks for your inputs community. I’ll set the watch to 3G then check battery consumption. Also, will try the 'Hands on Bright mode as well’s.
Any suggestions on how to make the watch display ‘Always ON’ with dim brightness?
May 28, 2018 18:56:09 GMT 1 casyjones said:
Who gets an unsecured wlan network called "NVRAM warning: Err..." in the wifi networks overview :-o
The lem7 Just don’t do it as smart as the les1 because the les1 got those Numbers around the Display. But the Bezel is a little bit bigger in the lem7. The lem7 is a Bit thicker, too.
But!!!
In my Case the fact that it runs so smooth is worth it. And If we Talk about battery it’s a two day usage with my moderate usage. les1 was about 1 day.
May 30, 2018 5:43:09 GMT 1 ashishaggarwal007 said:
Thanks for your inputs community. I'll set the watch to 3G then check battery consumption. Also, will try the 'Hands on Bright mode as well's.
Play store app for amoled screens
May 30, 2018 14:32:04 GMT 1 coolsly said:
Just a heads up:
Watch: Lemfo answered me the button was black, it’s in fact red. Lemfo said the agent was fired and when stating the screen was not fullscreen, they said the screen was fullscreen and it was a “the customer is not looking at the proper angle, our screen is full”. Lemfo really is a bad company when it comes to customer support. People should wait for another company to release an A7 watch that provides better service. It’s been stated by a few users, I state it too.
sorry, but you can never be sure about the info that you get on the selling site, Lemfo is'nt the manufacturer of the watch they just branded it under their name, still it is a good watch from reviews here about it, it is a full amoled 400x400 display and you can't find even in the premium watches that display and if so you pay high price in any technical problem you have us:) we do our best to improve the usage of full android watches i think they give more than any other smartwatches on the market with fair price tag. for now as i've seen there are 3 round display lte 4g watches but the only one with full info is the Lem7.
I just deleted a lot of clockskins from the clockskin folder (PC via USB). I only left two clocks.
But now I have a problem: after a couple of reboots the clock doesn’t show and I only have a black screen. Fortunately I can get via Floating toucher in settings so I have USB connection and access to apps. But somehow my stock launcher is broken.
Someone knows whats up? Factory data reset?
May 30, 2018 19:47:04 GMT 1 barnowl said:
that is not good you can't delete watch faces from the folder as long as you are on custom one you should always be on stock watch face to do so, you can add BUT you can't remove! the only option you have is to flash the watch with it's FW i'm not sure that factory reset will do the work.
pablo11
I did a factory reset and all is ok now. So you say I can delete watchfaces as long as I am on a stock watchface? So on a custom face no delete? Then there must be something in these stock watchfaces directories that makes that so.
Strange things, these smartwatches…
Thanks anyway.
OK thanks. I downloaded Always on amoled from PS. Will check.
Ok, I’ve done it again. Playing with some custom faces the watch is gone black again. And now there is no access to floating pointer so I can do no factory reset this time.
Help!..
May 30, 2018 23:56:18 GMT 1 barnowl said:
Ok, I've done it again. Playing with some custom faces the watch is gone black again. And now there is no access to floating pointer so I can do no factory reset this time.
Help!..
If you remove faces in future you should scroll along the end of the faces in the launcher UI and press the little refresh arrow.
Make sure you have selected a stock face before deleting any and always use the refresh button.
Is there any stock firmware around I can use?
