Lemfo lem6
Hey, I have a question for Lem6 users.
Actually a question about Tenfifteen F3, but I don’t know if anyone has that model, so lem6 would do, I hope.
When you remove the wrist strap, do the pins come off of the straps so that you can use them with replacement straps?
Or, are the pins stuck to the straps and you have to buy a new pair of pins to use with new straps?
Thanks!
all together and for the F3 do you owned, can we have the latest firmware
latest firmware for the lem6? do you mean A7? we will have to wait and see, i know that it might come to several watches just not sure which.
pablo11
I will ask for the latest version for you. It will be the same Android version. There is no A7 version for the LEM6. I'll let you know when I have it. My guess is that the latest version is whatever the last OTA was but I am not sure.
Pablo.
the Tenfifteen F3 have the Bluetooth calling feature and Lem6 don’t
Hi guys,
I would like to open some apps on my lem6 in zoom mode display (square) and others in normal display (rounded).
If I choose the zoom mode, all applications, except the manufacturer’s, are opened in a square window. How to make an app open in normal mode when the default mode is zoom?
Anybody know?
Jun 26, 2018 22:36:31 GMT 1 edisonb said:
you can't have you tried with Eric's launcher to check this out?    (ricktop)
you can’t have you tried with Eric’s launcher to check this out? (ricktop)
Nope, my launcher can’t do this.
Jun 22, 2018 5:59:30 GMT 1 soniasophie9697 said:
Jun 22, 2018 3:58:57 GMT 1 jjjalaska said:
Do you mean on the watch itself? If so then No, that’s can’t be done.
no, are the skins downloaded from the site round android watches for the clockwatchskin.
what?
Hi guys,
Anybody know?
This is what I used on LEM5 running on 5.0, I think? and should work on LEM6, too:
repo.xposed.info/module/jp.tkgktyk.xposed.niwatori
You can set the size of the window to your liking and toggle back and force by running the app shortcut.
Well, install the module and you’ll see what I mean.
Screen shift can give you presets, and modify size etc. of the display
it was a good try... but did not work. I could not simulate zoom display.
Hi guys,
Anybody know?
Xposed does not work on Android 5.1, arm architecture. But I'm analyzing at that code.
Thanks.
I’am missing apps like stopwatch, timer and a pedometer for small screens that I can start and stop the count whenever I want.
Does anyone know good apps like these?
you can’t have you tried with Eric’s launcher to check this out?    (ricktop )
Hi Eric.
I saw that your launcher has the action to put the display on Normal or Zoom mode, right?
What command do you use when we touch Zoom button?
I’am thinking about the possibility to create an app which changes the mode based on apps that are running.
Thanks.
Nope, my launcher can't do this.
Hi Eric.
Thanks.
I’m playing with “zoom_display” to 0 or 1 in system setting, but it does not work on many watches…
edisonb
timer - play.google.com/store/apps/developer?id=ricktop
padometer - why not ask someone from the great creators on the G+ community to creat one with big numbers?
Hi Eric.
Thanks.
great to know that somebody knows and have skill to do so,appreciated to come to  this community ,what about to make an app  or tasker for bluetooth connection to check every periods of time when the watch get disconnected in andoid and IOS.
I think is better to make a custom universal kernel(battery wakelock ,hibernation,display,connection,google services,watch idle, tasker,etc) working alone with Eric launcher
