How you do it
It’s no fair that Lemfo is doing this thing to us the owners of the Lem6 , because Tenfifteen have new smartwatch same as the Lem6 with the new Bluetooth calling feature and us we don’t have nothing , we us owners of this device we most go to their website in write a feedback to theme and say why
Jan 17, 2018 18:00:44 GMT 1 leafar said:
How you do it
Use Mobileuncle MTK ToolHero
Open “Engineering mode” - “Connectivity” - “Bluetooth” to edit “BT RX ADC Clock selection” value - Turn on.
i am really happy with the watch getting two days with bluetooth sometimes wifi but no much i donnt need it,the russian firmware fantastic,no play store i dont need it,the bluetooth working perfect little delay with my iphone 8 plus,much better than Android that i use to have before,i use to be an android person,no any more.
jus waiting for Jinvice and Bmarko82 for something good.
i just want a full stand alone smartwatch,with bluetooth calling festures and good battery life.
Hi I receive my lem 6 three days ago. It is very nice watch with lot of capabilities. The gps working fine also the wifi and the Bluetooth. I load also the eric’s launcher working nicely.
But I have a question for those who have this watch.
Do you have any weather info? Because I try to have some info from the default app of the the watch but didn’t show me nothing.
I’m connected to the internet and the GPS switched on but nothing. Do you have any idea to solve the problem?
Thanks in advance!
Jan 20, 2018 17:03:27 GMT 1 jim10 said:
Hi I receive my lem 6 three days ago. It is very nice watch with lot of capabilities. The gps working fine also the wifi and the Bluetooth. I load also the eric's launcher working nicely. But I have a question for those who have this watch. Do you have any weather info? Because I try to have some info from the default app of the the watch but didn't show me nothing. I'm connected to the internet and the GPS switched on but nothing. Do you have any idea to solve the problem? Thanks in advance!
open the weather app, you have to wait like a minute or so,just turn on the GPS,with the WIFI,but remember to turn of because the drain battery for the GPS. so how much in battery you have with Google services,because i do have the russian firmware.
Can’t decide whether to go for LEM6 or Tenfifteen F3. The same watch but with minor cosmetic differences to the watch case but F3 has the bluetooth call feature already. Does anyone want to hazard a guess on whether Lemfo will send a firmware update to add this feature??
I just get a LEM6 a few days ago. After a lot of vain research I found this thread but with no solution to add faces.
So I tried and… It’s soooo easy !
Just create a ClockSkin directory on storage and put android watch faces (not apk but with XML files) in sub-directories inside it.
Reboot (not sure this is needed) and have fun !
Will post photos
It was an updated please can someone tell me version number and if it’s something good , because I do have the Russian firmware
I used the “default” rom of the LEM6 and it offered a Wireless update.
In fact it was the update of Decembre and I did it (7.8 MB).
Now the watch offer another update (see attachments).
Does anybody know where the downloaded file is located ?
Let’s hope that they have fixed the Bluetooth disconnect issues with this OTA.
Does anyone know how to enable accessibility for apps? I am unable to find toggle button/option to enable it due to round shape and small resolution.
yes, here the work-around:
Dec 30, 2017 2:14:10 GMT 1 jinvice said:
drive.google.com/file/d/1SKTddIJeabXN14ynJc1tHj25yo6hZy7r/viewhere is a working TWRP.
Just use flashify, because recovery touch don’t work.INSTRUCTIONS:
- Start SP Flash Tool, add scatter-loading file
- Check JUST Recovery, uncheck boot.img
- Press DOWNLOAD
- Plug lem6
- Install Flashify
- Now you can do everything you would.
NOTE: I higly reccomand to get root before.
NOTE2: if you have some problems, check this:
/thread/1703/lemfo-lem6?page=5&scrollTo=18019
Can you re-upload your TWRP? The link is broken
Owner of this device be careful because mine just broken where you change the band, the material that they use the hard plastic is cheap and I am not even use the watch to tied
Hello people,
I’m having problems with the watchclockskin laucher on my lemfo lem 6, some functions of the skins do not work, the skins act as in the same way as in the original launcher of the watch. What should I do ?
You mean the stock launcher, maybe do a factory reset and start all over again
Jun 14, 2018 5:30:58 GMT 1 jjjalaska said:
Hello people, I'm having problems with the watchclockskin laucher on my lemfo lem 6, some functions of the skins do not work, the skins act as in the same way as in the original launcher of the watch. What should I do ?
what?
I installed watchclockskin launcher, when I try to change the color of a skin it does not change, it only gives the option to change the skin
Jun 22, 2018 3:58:57 GMT 1 jjjalaska said:
Do you mean on the watch itself? If so then No, that's can't be done.
